fowading port 25
is there a way of forwarding all mail port 25, to use a specific interface to go out with because i have two wan interfaces and i would only like it to use the one
Use the firewall mangle rules to mark port 25 connections for routing out the correct interface before other load balancing rules(assuming you have them) with passthrough set to no, and then set up your NAT rule.
