I have that configuration:
add address=85.122.79.246 netmask=255.255.240.0 interface=ether1
add address=85.122.79.40 netmask=255.255.255.248 interface=ether2
/ip route add gateway=85.122.64.1
add address-pool=static-only authoritative=yes bootp-support=static disabled=no interface=ether2 lease-time=3d name=dhcp1
config set store-leases-disk=immediately
network add address=85.122.79.40/29 comment="" dns-server=85.122.79.253,85.122.79.254,193.231.236.10 gateway=85.122.79.41
lease add address=85.122.79.42 comment="" disabled=no mac-address=00:08:74:EF:DF:B3 server=dhcp1
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=4096KiB max-udp-packet-size=50 primary-dns=85.122.79.253 secondary-dns=85.122.79.254
i set:
/ip firewall filter add chain=forward action=accept
When i start the machine i recive the ip 85.122.79.42 but the connection don’t work
the configuration with masquerade is working:
lease add address=85.122.79.42 comment="Tepes" disabled=no mac-address=00:08:74:EF:DF:B3 server=dhcp1
/ip firewall nat add chain=srcnat src-address=85.122.79.40/29 action=masquerade
add chain=input connection-state=established comment="Accept conexiunile stabilite"
add chain=input connection-state=related comment="Accept conexiunile legate"
add chain=input connection-state=invalid action=drop comment="DROP la conexiunile invalide"
add chain=input protocol=udp action=accept comment="UDP" disabled=no
add chain=input protocol=icmp limit=50/5s,2 comment="Limitez pingul.."
add chain=input protocol=icmp action=drop comment="... si branza la exces"
add chain=input in-interface=ether2 src-address=85.122.79.40/29 comment="Accept ce vine din LAN" action=accept
add chain=input action=drop comment="DROP orice altceva"
I need some help please
