FR: winbox add auto-reconnect (feature request)
I would love to see an auto reconnect feature to be added to winbox.exe (disabled by default ofcouse).
Such that when winbox.exe is connected to a rOS device, you can enable a feature /drop-down menu option (in winbox) that will auto-reconnect in the event the connection is dropped.
thanks
(btw- i thought there used to be a forum topic dedicated to just winbox, but i may be mistaken.)
