have an MTU that is set too high. It will just break when you send a labelled packet which is too big for a router (:mpls interface) or interface (:interface) in LSP.
Have you tried stacking vlans over and over, putting an IP on the innermost vlan and ping large packets to the router on the other side through the VPLS? It would require a similar setup on the other side to get a response though. This works around the IP MTU quirks in RouterOS and you can add as many as you want in increments of MPLS label size. You could potentially use the method to monitor inside the VPLS.
