Framed-IP-Address not showing on FreeRadius
Hi there guys,
Hoping someone can provide some insight into a issue i am having.
We have multiple vendors connecting through a Radius server but with the Mikrotiks i seem to have an issue receiving the Framed-IP-Address.
The user devices receive a IP address from a Windows DHCP server.
I dont see where i can extend the delay timer for the accounting on the mikrotik.
I am using a CHR as a CAPsMAN server with hAP lites and hAPs. All traffic is local offloading if that makes a difference
Appreciate any feedback and guidance
please confirm that the mikrotik is your RAS.
which type of connection you are providing? (pppoe,pptp,hotspot,etc…)
are you using freeradius?
The Mikrotik CHR is running as a CAPsMAN controller and provides the Wireless settings to the multiple Mikrotiks APs on our campus with RADIUS authentication enabled
My Radius Server settings are set to allow wireless to my FreeRadius server address.
My Security Configuration has WPA2 EAP with AES enabled and the EAP method is passthrough.
the attributes come through as Framed-User to FreeRadius
