Framed Route on Chateau 5G
I have a Chateau 5G with a SIM with a profile that support the Framed Routes.
Where I can find a documentation to setup it right on the Chateau if it is supported?
Because, from what I see, the ping traffic is correctly forwarded but the TCP traffic seems to be dropped (the firewall is disabled).
Hi
did you got the solution for this problem ? I am also facing this issue
Same issue for me… Mokrotik support any feedback? is frame routing supported by chateau 5G???
Ask support via support@mikrotik.com to be sure.
This is a user forum, they don’t read everything on this place.
Solution found
  • deactivate NAT (in webui, IP/Firewall/NAT)
  • deactivate firewall rule of forwarding based on NAT (inwebui, IP/Firewall/Filter Rules : deactivate "drop all from WAN not DSTNated)
  • using terminal, send following AT command [admin@MikroTik] > /interface lte at-chat [find] input=“AT+QLOGMASK="DPL",1”
need to make a hardware reboot for AT command to be taken into account
@gprono which mini cpie you are using. Cant run this command. We have MSNX1031C or techship mp101-s. Or how do you find correct command for my Mini PCIE i.e /interface lte at-chat input=“AT.. what after ?
