Actually I have varios R2N mini pci radios on production, but they are discontinued, this wokrs fine, really, frecuency range’s R2N is 2.192 - 2.539GHz (5 MHz step) on 2,4 ghz, my question is, R52hN support the same range’s frecuency on 24, ghz?, and which is on 5 ghz?, I can found this information on DS R52hN, can anybody help me?, thanks in advanced.
Ariel Horas
Gerente de Operaciones
Systemas MicroInformaticos
I haven´t installed yet R52nH on routerboard, my question is becouse only I have R2N, but this was discontinued and I need have a replace if R2N dosen’t work more, whith the same features. There are to many branch radios that in theory suports this frecuency range but they aren’t has good perfomance and stability on real operation.
This question is because on R2N’s data sheet frecuency range is specified the posted range but is not on R52nH’s data sheet.
Ariel Horas
Normis…your answer is correct, if routerboar shows all frecuencies mini-pci works on them?, becose I test to many boards that list ferecuency but only works fin on 2,4 ghz range, for this is my post, can you help me or tell me where is spec of r52HN?.
