mangot
September 12, 2008, 8:36am
1
I am used to ROS on x86 platform, but a newbie with routerboards.
I just got my firsts RB433, and, to be coherent with my x86 Routers (I have 20 of them), decided to upgrade them to v3.13 ROS.
After upgrade, I saw that the free hdd memory had falled from 33,9 Mb down to 10,5 Mb !
Is this a normal behaviour ? Making just an upgrade nearly saturates the hdd resource ?
Thanks for your help.
normis
September 12, 2008, 8:44am
2
did you install some additional packages, that you didn’t have before? try uninstalling stuff that you don’t use. also check the files menu, maybe there are some backups. also I gather you don’t use proxy there?
mangot
September 13, 2008, 8:06am
3
Thanks, normis.
Obviously, you were right. I uninstalled some unused packages, and got back 22452 kb.
There is also autospout backup files, but no proxy data.
My problem was that on x86 platform, you don’t really follow disk storage, as you have Gbs… With Routerboards, you have to be more acurate.
Thans for your quick help.
