I’m trying (whitout success) to authenticate mikrotik on radius freeipa server with ldap backend.
Has anyone been successful?
Hi!
Maybe this is no longer relevant, but I answer.
I successfully implemented a bunch of centos 8 + freeipa 4.8.4 + freeradius 3.0.17 + mikrotik 6.47.
Some unobvious moments for me. FreeIPA has default password hash is PBKDF2_SHA256, but FreeRADIUS not support it. You must change FreeIPA hash.
Mikrotik’s RADIUS client use MSCHAPv2 for auth. MSCHAPv2 support only clear text hash or NT HASH. You must add support NT HASH to your FreeIPA.
But but still it works! And I can connect to Mikrotik’s L2TP-server with my LDAP login.
Hi mekatum,
I have the same problem. Newly installed FreeIPA with LDAP + freeradius.
Connections between Huawei, Cisco devices and FreeIPA server over the freeradius is OK but MikroTik doesnt work.
My questions is, how I change FreeIPA hash? Or how I add support NT HASH to my FreeIPA server?
Thank You for help.
Best
Plnt
we used OpenLDAP with freeRadius and use cleartext pass for Mikrotik and other vendors Cisco, Huawei, Zyxel…
We made similar setup as you “I successfully implemented a bunch of centos 8 + freeipa 4.8.4 + freeradius 3.0.17 + mikrotik 6.47.”, but we cant authenticate on Mikrotik via this setup.
Please, could you help us in some way?
Thanks.
Yosefko
I burnt a lot of time trying to get this to work.
- most guides are 5+ years old
- everyone that’s giving advice and tips seems to be using different versions
- security issues trying to get this to work
The list kind of just goes on.
If someone could do a write up of all the steps needed for a fresh install of FreeIPA + FreeRADIUS I’m sure a lot of people would find it useful.
I gave up and just made a dedicated RADIUS server for mikrotik logins ![]()
I had managed to get this working with CentOS 8, Freeipa, freeradius and a mikrotik router.
Up until (I suspect) the upgrade to RouterOS 7 it was working, but something has changed and the MSCHAP challenge is no longer working.
For background, I had used a number of guides that firstly use the FreeIPA - AD trust setup (don’t need AD, just run the AD specific setup as it generates the NTHASH needed for mschap challenge) and then set up a service account with a specific permission to access the NTHASH as FreeIPA doesn’t allow anonymous browsing.
Using radtest direct on the freeradius server, the MSCHAP challenge works. But now it fails with the Mikrotik RADIUS client. If I get to the bottom of it I’ll update this post.
Looks like something’s changed on the Mikrotik end, I’m now running RouterOS 7.7 and login against a FreeRadius server again works.
