Freelance Mikrotik RB1200 Programmer Needed
Hi
I know there is a lot of information around to configure these routers, but I now need help to do this and am willing to pay.
Please will you pm me with quotes for the below to configure.
I need two Mikrotik RB1200 routerboards configuring to the following spec.
These routers are in two different locations.
Router 1 needs to have wan fall over across three connections. Wan’s 1 and 2 have a pppoe connection and Wan 3 is connected to a cable DSL router.
Wan 1 has 6 static IP address, Wan 2 has one static IP address but Wan 3 has a dynamic IP address.
Ethernet ports 5,6,7,8 and 9 needs to be on different subnets, with no DHCP turned on.
Port 5 subnet is 192.168.0.0/24
Port 6 subnet is 192.168.4.0/24
Port 7 subnet is 192.168.5.0/24
Port 8 subnet is 192.168.6.0/24
Port 9 subnet is 192.168.8.0/24
Subnet 192.168.4.0/24 is to have QOS for traffic on ports 5060 & Asterisk ports
Subnet 192.168.0.0/24, 192.168.6.0/24 and 192.168.8.0/24 must not be accessible from the outside world but 192.168.4.0/24 and 192.168.5.0/24 needs to be forwarding ports.
Router 2 needs to have wan fall over across two connections. Wan 1 is an optical connection from another router with a dynamic IP address and Wan 2 is static from a DSL router.
Ethernet port 5 needs to be on subnet 192.168.7.0/24 with no DHCP turned on.
Both routers need to have a VPN connection between them using Openvpn or SSTP
Router 1 primary needs to be the server and router 2 needs to be the client, this is because the VPN needs to be configured using router 2’s optical line which has a dynamic IP address.
The VPN form subnet 192.168.7.0/24 is allowed to access 192.168.4.0/24 and 192.168.5.0/24 only and QOS has to be applied to port 5060 and Asterisk Ports.
A fail safe for a second VPN needs to be applied using the static of wan 2 connection if the first optical dies.
Both routers need to have firewall rules in place for port scanning, floods and spam ECT.
Both routers will be available with IP address to login and configure. Router 2 has both of its Wan’s connected and router 1 has two of the three wan’s connected as we are using wan 1 in our present configuration.
We have had these routers now for 3 months, I know we should be able to configure these ourselves but after various configurations and several hours of work have gone into trying to configure with no fully working configuration.
Regards
Simon
Simon.
I’m willing to help you.
Please send mail to ruud[dot]de[dot]vries@xs4all[dot]nl
Check my signature and send me and email
Regards
