We have a Radius server running Freeradius with mysql backend. We use it for pptp authetication and everything works fine. I would just like to know what attribute or setting needs to be changed to have custom names for the simple queues. Currently the queue gets the name of the authenticated user. eg.
I don’t think it is possible, those dynamic queues are created by RouterOS automatically. You would need to request MikroTik to add an option to change that behavior. In Mikrotik documentation I did not find any configuration option nor did I find a Radius dictionary attribute to affect the name.
One solution would be to not use those automatic queues and create a script to create those queues with your chosen names. The script would be difficult to create. Try writing a perl or php script that pulls a list of your current users from the MySql database your FreeRadius server uses. Have that script create a page on a web server for your RouterOS router to download using the fetch command and create and/or update the queues every 5-10 minutes.
Another solution would be to create manual rules, you might need to have your radius server assign out static IP addresses to keep each client in the proper queue.
I actually don’t see the need to change the naming of the queues. Only you and your support staff normally see the queues, you can hide the queues graphs on your web-interface of your router to keep your clients from seeing the queues & queue names.
I have finally solved it by assigning the mikrotik-rate-limit command from the radiu and so mikrotik assigns a single queue to each pppoe connection, I hope I have helped you
once updated the dictionary you can see how there is an option that is
Mikrotik-Address-List.
Well you have to use that option, for this in mikrotik you will create an address list 10Mbs for example and now in the radius you assign that address list to the radius user and it automatically creates the tree queue.
if you have any doubt tell me and I try to help you.
I just have to know how I can change some radius parameter and that the client is replicated more or less automatically, now every time I make a change of speed or ip, I have to disconnect the user so that the radius returns to set the new parameters
