freeradius and simultaneous logins
Hi guys,
I’d like know how make to allow only login simulaneous with freeradius and pppoe. I found Simultaneous-Use attribute, but I not found it in freeradius documentation and I not see it in freeradius dictionaries.
thank you.
In the docs direcotry, is a text file called Simultaneous-Use, I suggest you use it.
You need far more than just a simple attribute name…
Hrorber,
I use this http://www.dmasoftlab.com/cont/home
:slight_smile:
hey guys
thanks for replies.
I solved this problem fallowing this steps:
I edited sql.conf. uncommented this line:
simul_count_query = “SELECT COUNT(*) FROM ${acct_table1} WHERE UserName=‘%{SQL-User-Name}’ AND AcctStopTime = 0”
After, in radcheck:
UserName            attribute                   op          value
foo@foo.com.br    Simultaneous-Use    :=           1
It’s works to me.
Thank you.
Under high load, when you start missing Radius Accounting Stop messages, you’re still going to have issues.
You need to implement and make use of the checkrad script as well…
HI savage, It is very old post but if possible could you please post here how to do this. Sometimes my users session still active on radius server “acctstoptime=null”. I can`t remove this session. When I try to use disconnect message from radius, mikrotik replies incorrect IP address of session (of course. because no active session on the router itself)
