Found out that, it assigns IP, address-list and rate limit fine if only I enter debugging mode: freeradius -X
here is a log:
Ready to process requests.
rad_recv: Access-Request packet from host 149.30.11.107 port 60203, id=128, length=120
NAS-Port-Type = Ethernet
NAS-Port = 2202009973
Calling-Station-Id = "1:e8:99:c4:b7:a:87"
Framed-IP-Address = 192.168.100.3
Called-Station-Id = "server1"
User-Name = "E8:90:C4:B5:01:88"
User-Password = ""
NAS-Identifier = "MikroTik"
NAS-IP-Address = 192.168.100.2
Executing section authorize from file /etc/freeradius/sites-enabled/default
+- entering group authorize {...}
++[preprocess] returns ok
++[chap] returns noop
++[mschap] returns noop
++[digest] returns noop
[suffix] No '@' in User-Name = "E8:90:C4:B5:01:88", looking up realm NULL
[suffix] No such realm "NULL"
++[suffix] returns noop
[eap] No EAP-Message, not doing EAP
++[eap] returns noop
++[files] returns noop
[sql] expand: %{User-Name} -> E8:90:C4:B5:01:88
[sql] sql_set_user escaped user --> 'E8:90:C4:B5:01:88'
rlm_sql (sql): Reserving sql socket id: 4
[sql] expand: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radcheck WHERE username = 'E8:90:C4:B5:01:88' ORDER BY id
[sql] User found in radcheck table
[sql] expand: SELECT id, username, attribute, value, op FROM radreply WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radreply WHERE username = 'E8:90:C4:B5:01:88' ORDER BY id
[sql] expand: SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority -> SELECT groupname FROM radusergroup WHERE username = 'E8:90:C4:B5:01:88' ORDER BY priority
rlm_sql (sql): Released sql socket id: 4
++[sql] returns ok
++[expiration] returns noop
++[logintime] returns noop
[pap] WARNING: Auth-Type already set. Not setting to PAP
++[pap] returns noop
Found Auth-Type = Accept
Auth-Type = Accept, accepting the user
Executing section post-auth from file /etc/freeradius/sites-enabled/default
+- entering group post-auth {...}
++[exec] returns noop
Sending Access-Accept of id 128 to 149.30.11.107 port 60203
Framed-IP-Address := 192.168.88.100
Mikrotik-Address-List := "test"
Mikrotik-Rate-Limit := "512k/2500k"
Finished request 0.
Going to the next request
Waking up in 4.9 seconds.
rad_recv: Access-Request packet from host 149.30.11.107 port 60025, id=129, length=114
NAS-Port = 2202009974
User-Password = ""
rlm_sql (sql): Reserving sql socket id: 3
rlm_sql (sql): Released sql socket id: 3
++[sql] returns ok
Sending Access-Accept of id 129 to 149.30.11.107 port 60025
Finished request 1.
Waking up in 3.8 seconds.
Cleaning up request 0 ID 128 with timestamp +9
Waking up in 1.1 seconds.
Cleaning up request 1 ID 129 with timestamp +10
