freeradius + Mikrotik bug?
Hello all,
I am running MT v2.8.28 and have set it up to authenticate hotspot users through freeradius.
During my initial tests I was almost always running freeradius in debug mode and did not encounter any problems.
After I finished testing, I started freeradius without the debug flag and suddently the authentication started giving the error “Radius server not responding” about 3 / 5 out of the attempts.
After some investigation I found that I can also solve this problem by running freeradius with the -s (single thread mode) flag (which is implied by the -X itlself).
I do not believe that running freeradius in single mode is good and have been unable to bypass this. I am able to connect using the radtest command regardless of the flags I use. Is it a bug in Mikrotik?
Thanks,
Hedgy
No. Not Mikrotik RouterOS.
Sounds like you have a threading problem.
It must be your problem because it works perfectly with radiator…
I downloaded the 2.9 trial and it worked without a glitch.
I also tested using a D-link controller and it worked perfectly.
This problem seems to be specific to the version I have :frowning:
MT working fine with freeradius for me since versions 2.6 and 0.8 till 2.9.1 and 1.0.2
Changed the hardware the radius server was running on and the problem is now solved.
At least one person seems to have had the same problem.
http://lists.freeradius.org/pipermail/freeradius-users/2004-December/038836.html
I just hate it when I get a solution without a clear explanation :slight_smile:
