freeradius mikrotik
Hi, I have configured freeradius to authenticate PPTP users from MT and it is working fine now I need help regarding the ip pool configuration on freeradius. I need defferent ip addresses for different group of users.
anybody ???
thx
Hi goodone
This is not really a Mikrotik question you are asking.
I suggest naming your IP Pools eg pool1, pool2 etc, and when setting up a user on FreeRADIUS, specify that pool name under named-pool.
If you choose to use pool2 as default IP pool under your PPPoE Profiles, and you don’t specify a pool on FreeRADIUS, pool2 would be chosen by default. Also remember to specify a LOCAL IP address in your PPPoE Profile, otherwise you’ll get an error saying “could not determine local IP address”
I hope this helps
Even better, get User Manager! I’m moving away from Radius myself, just waiting for a few more functions to be added to UM.
Re, G
