Freeradius Restrict User Auth Request Based on VLAN
Scenario:
We have One Mikrotik CCR as NAS (pppoe) and Freeradius as billing. Multiple area’s are connect to Mikrotik via Cisco switch & VLAN are configured for each port.
We have few reseller/frenchise managers, like Dealer-A, Dealer-B.
They can create there own users in freeradius using frontend GUI designed in php. All dealers can view/edit there own users only.
Sometimes it happens that Dealer-A creates ID and give it to a user/friend who is sitting in Dealer-B network, therefore from Billing perspective its a Loss for Dealer-B.
Can we add some restriction so that User-ID’s created by each dealer should be able to connect only from his network (or from there own VLAN) only.
Are you using hotspot or ppppoe?
Either way, you should be creating seperate hotspot/pppoe server per vlan. Then just check the access-request packet, there is an attribute you can use I think it’s caller-id, you can use that on freeradius to then allow/deny access as you wish
Ok I added this in RADCHECK table.
NAS-Port-Id == VLAN2
& it seems to be working fine.
Is there any way I can customized the radreply if user gets rejected dueto incorrect VLAN (for log purposes)
Example of one module I have that checks for Invalid MAC.
checkval{
reject = 1
if(reject){
ok
update reply {
Reply-Message := "Incorrect MAC!"
Framed-Pool := "invalid-mac-address-pool"
Mikrotik-Rate-Limit := "1k/1k"
I want something similar for the Incorrect VLAN users.
is it possible?
Ok I was able to sort it.
if ("%{sql: select vlanid from users where username = '%{User-Name}'}" != "%{NAS-Port-Id}") {
  update reply {
                Reply-Message = 'You are not allowed to connect from this VLAN'
update control {
Auth-Type := "Reject"
It’s added under Authorized Section. Will write in details about it if some one required.
