I am having some problems with the “session-time-left”-variable, I can’t make it work when using my FreeRadius central server.
I have opened port 1700 UDP to the NAS, activated “interim updates” and things like that, the FreeRadius server is set to remotely disconnect users etc when limit reached and all is working well. The only problem is that they only see how many minutes this current session has been online, not how many minutes that is left.
Normally, you would know. That is an entry in radreply for that user. Unless you are returning one of those values from the RADIUS server, the router will not know about it.
If there is a value in session-time-left, the time remaining will be displayed on the default status.html page. Mine does, and I use WISPr-Session-Terminate-Time.
You can see what is being sent and returned by enabling radius logging, then check the log after a login.
Thanks for all your help!
I haven’t engaged time enough for all the details of the radius server so I didn’t know about these fields.
I will investigate why its not sending this as it is the most likely reason.
