Freeze terminal
I have a problem with one of the RB 411 (4.16). terminal does not work and reboot the device does not help. Do you have someone with this experience or any solution? Thanks for the answer.
If you can’t console in, try netinstall. If that doesn’t work contact your reseller.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Default baud rate on a routerboard is 115200.
I don’t have problem with somethink else…only freeze terminal. Can load and operate by winbox without problems and there terminal doe’s not work. The same thing when I connect from transmitter to the connection via MAC-telnet , it just freezes.
Then check your Console and MAC Telnet settings in the routerboard.
http://wiki.mikrotik.com/wiki/MAC_access
http://wiki.mikrotik.com/wiki/Manual:System/Serial_Console
http://wiki.mikrotik.com/wiki/Manual:Console
