hello everybody i have a pc router, with 5 Pc Card, 4 Sectors ( 2 Vertical, 2 Horizontal), and one Omni all of them are 2.4 Ghz, but i dont know which cannels are better for these, because sometimes they create interferance to other sektors..can anybody tell me what frequency use for these 5 interfaces..
THankYOu
Assuming you are using seperate channels for each sector, this may be a difficult task to accomplish. Your omni is likely to be the sector that suffers the most (what will you be using that for?) Make that your most distant channel, say 11. Try to have good physical seperation between antennas (6ft or more), and try to keep your Tx power close to being the same at all antennas. If I had 18 feet of vertical space on a tower, I would use ch 11 on the omni, then channel 1 on the next closest antenna, then 8, 3, and 5.
If you are not looking for different ch/ sector, simply run a scan off the omni, locate the strongest signals and what channels they are on, and pick one where they are not. However, I would still maintain good physical antenna seperation on the tower.
