Hello
I have Pacific Wireless Sector Antenna witch support the frequency range 2300 - 2700, and i would like to test it, i have ubiquity XR2, SR2, and mikrotik R52h, using RB333 board, witch of this card could work at this frequency range?
Hello
Look up the specs. Geeze.
If you do want to try it out, first thing you’ll need is a card that supports the frequencies. Second thing you’ll need is a superchannel license so you can set the frequencies in the software.
