Hello
I have som sites witch is near each other, an I`m planing on using MT P2P links.
If I use 5180Mhz on one site and 5200Mhz on the other, 20Mhz resoluton, will they interfear with each other?
Hello
In the 2.4Ghz spectrum we have 3 non-overlapping channels ie. 1, 6 and 11 with 4/5 channels of seperation (not too sure about the bout of channels ow).Basically, to minimize interference you should stay about 4 channels apart from each other. 5.8 Ghz uses OFDM and that makes it possible to just use seperate channels, without the need of any amount of channels of seperation.
