Verbose Config is
# aug/26/2019 15:46:04 by RouterOS 6.45.3
# software id = W17Q-5CBC
# model = RouterBOARD 941-2nD
# serial number = 6616077DB521
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no \
disabled=no fast-forward=yes forward-delay=15s igmp-snooping=no \
max-message-age=20s mtu=auto name=br_AdminNet priority=0x8000 \
protocol-mode=rstp transmit-hold-count=6 vlan-filtering=no
max-message-age=20s mtu=auto name=br_GuestNet priority=0x8000 \
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto \
auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
full-duplex=yes l2mtu=1598 loop-protect=default \
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
64:D1:54:42:2C:C3 mtu=1500 name=ether1 orig-mac-address=64:D1:54:42:2C:C3 \
rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=\
64:D1:54:42:2C:C4 mtu=1500 name=ether2 orig-mac-address=64:D1:54:42:2C:C4 \
set [ find default-name=ether3 ] advertise=\
64:D1:54:42:2C:C5 mtu=1500 name=ether3 orig-mac-address=64:D1:54:42:2C:C5 \
set [ find default-name=ether4 ] advertise=\
64:D1:54:42:2C:C6 mtu=1500 name=ether4 orig-mac-address=64:D1:54:42:2C:C6 \
/queue interface
set br_AdminNet queue=no-queue
set br_GuestNet queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
include="" name=dynamic
set [ find default=yes ] authentication-types="" disable-pmkid=no \
eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m \
interim-update=0s management-protection=disabled mode=none \
mschapv2-username="" name=default radius-called-format=mac:ssid \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-sta-private-algo=none static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=\
no-certificates unicast-ciphers=aes-ccm
add authentication-types=wpa2-psk disable-pmkid=no eap-methods="" \
group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=allowed mode=dynamic-keys mschapv2-username="" \
name=sp_AdminWifi radius-called-format=mac:ssid radius-eap-accounting=no \
radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
supplicant-identity="" tls-certificate=none tls-mode=no-certificates \
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
0 area="" arp=enabled arp-timeout=auto band=2ghz-b/g basic-rates-a/g=\
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
compression=no country="south africa" default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=\
yes disable-running-check=no disabled=no disconnect-timeout=3s distance=\
dynamic frame-lifetime=0 frequency=2412 frequency-mode=regulatory-domain \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 installation=any \
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
mac-address=64:D1:54:42:2C:C7 max-station-count=2007 mode=ap-bridge mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=\
wl_AdminWifi noise-floor-threshold=default nv2-cell-radius=30 \
nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-noise-floor-offset=\
default nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both \
radio-name=64D154422CC7 rate-selection=advanced rate-set=default \
rx-chains=0,1 scan-list=default secondary-channel="" security-profile=\
sp_AdminWifi ssid=Senzis station-bridge-clone-mac=00:00:00:00:00:00 \
station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1 \
tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=any wmm-support=\
disabled wps-mode=push-button
add area="" arp=enabled arp-timeout=auto bridge-mode=enabled \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
0 default-forwarding=yes disable-running-check=no disabled=no hide-ssid=\
no interworking-profile=disabled keepalive-frames=disabled l2mtu=1600 \
mac-address=66:D1:54:42:2C:C7 master-interface=wl_AdminWifi \
max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=\
disabled multicast-helper=default name=wl_GuestWifi security-profile=\
default ssid="Senzis Customer Wifi" station-bridge-clone-mac=\
00:00:00:00:00:00 station-roaming=enabled update-stats-interval=disabled \
vlan-id=1 vlan-mode=no-tag wds-cost-range=0 wds-default-bridge=none \
wds-default-cost=0 wds-ignore-ssid=no wds-mode=disabled wmm-support=\
disabled wps-mode=disabled
/interface wireless manual-tx-power-table
set wl_AdminWifi manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbp\
s:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,\
HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20\
-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:1\
7,HT40-7:17"
/interface wireless nstreme
set wl_AdminWifi disable-csma=no enable-nstreme=no enable-polling=yes \
framer-limit=3200 framer-policy=none
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
transparent-proxy=no
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=\
0.0.0.0:0 login-by=cookie,http-chap,trial name=default rate-limit="" \
smtp-server=0.0.0.0 split-user-domain=no trial-uptime-limit=30m \
trial-uptime-reset=1d trial-user-profile=default use-radius=no
add dns-name=senzis.local hotspot-address=10.5.50.1 html-directory=hotspot \
html-directory-override="" http-cookie-lifetime=3d http-proxy=0.0.0.0:0 \
login-by=cookie,http-chap,trial name=hsprof1 rate-limit="" smtp-server=\
0.0.0.0 split-user-domain=no trial-uptime-limit=30m trial-uptime-reset=1d \
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m \
dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 \
lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
modp1024
add name=dhcp_pool0 ranges=10.0.0.20-10.0.0.198
add name=hs-pool-7 ranges=10.5.50.2-10.5.50.254
add address-pool=dhcp_pool0 authoritative=yes bootp-support=static disabled=\
no interface=br_AdminNet lease-script="" lease-time=10m name=dhcp1 \
use-radius=no
add address-pool=hs-pool-7 authoritative=yes bootp-support=static disabled=no \
interface=br_GuestNet lease-script="" lease-time=1h name=dhcp2 \
use-radius=no
/ip hotspot
add address-pool=hs-pool-7 addresses-per-mac=2 disabled=no idle-timeout=5m \
interface=br_GuestNet keepalive-timeout=none login-timeout=none name=\
hotspot1 profile=hsprof1
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost \
!bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout \
!incoming-filter !insert-queue-before !interface-list !local-address \
name=default on-down="" on-up="" only-one=default !outgoing-filter \
!parent-queue !queue-type !rate-limit !remote-address !session-timeout \
use-compression=default use-encryption=default use-mpls=default use-upnp=\
default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost \
name=default-encryption on-down="" on-up="" only-one=default \
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address \
!session-timeout use-compression=default use-encryption=yes use-mpls=\
default use-upnp=default !wins-server
/interface pptp-client
add add-default-route=no allow=pap,chap,mschap1,mschap2 connect-to=\
kolbep.ddns.net dial-on-demand=no disabled=no keepalive-timeout=60 \
max-mru=1450 max-mtu=1450 mrru=disabled name=kolbep.ddns.net profile=\
default-encryption user=senzi1
/queue interface
set kolbep.ddns.net queue=no-queue
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set wl_AdminWifi queue=wireless-default
set wl_GuestWifi queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id \
!confederation disabled=no ignore-as-path-len=no name=default out-filter=\
"" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=\
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id \
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 \
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 \
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
!routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 \
encryption-protocol=DES name=public read-access=yes security=none \
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=\
default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=\
default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api,romon,dude,tikapp" skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled \
mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" \
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=ram crl-use=yes
add auto-isolate=no bpdu-guard=no bridge=br_AdminNet broadcast-flood=yes \
disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none \
hw=yes ingress-filtering=no interface=ether1 internal-path-cost=10 learn=\
auto multicast-router=temporary-query path-cost=10 point-to-point=auto \
priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no \
trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
ingress-filtering=no interface=wl_AdminWifi internal-path-cost=10 learn=\
add auto-isolate=no bpdu-guard=no bridge=br_GuestNet broadcast-flood=yes \
ingress-filtering=no interface=wl_GuestWifi internal-path-cost=10 learn=\
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
yes send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none \
lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 \
caller-id-type=ip-address default-profile=default-encryption enabled=no \
keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited \
mrru=disabled one-session-per-host=no use-ipsec=no
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=\
no keepalive-timeout=60 mac-address=FE:1F:00:41:0F:3E max-mtu=1500 mode=\
ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 \
max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any \
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.0.5/24 disabled=no interface=br_AdminNet network=10.0.0.0
add address=10.5.50.1/24 comment="hotspot network" disabled=no interface=\
br_GuestNet network=10.5.50.0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set accounting=yes interim-update=0s store-leases-disk=5m
add address=10.0.0.0/24 caps-manager="" dhcp-option="" dns-server=\
10.0.0.5,10.0.0.2 gateway=10.0.0.2 ntp-server="" wins-server=""
add address=10.5.50.0/24 caps-manager="" comment="hotspot network" \
dhcp-option="" dns-server="" gateway=10.5.50.1 ntp-server="" wins-server=\
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-concurrent-queries=100 max-concurrent-tcp-sessions=20 \
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s \
servers=10.0.0.2,8.8.8.8
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
"place hotspot rules here" disabled=yes !to-addresses !to-ports
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.5.50.0/24 !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
disabled=no name=default-trial
add disabled=no name=admin profile=default
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
max-cache-object-size=2048KiB max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref \
!bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1 \
dst-address=0.0.0.0/0 gateway=10.0.0.2 !route-tag !routing-mark scope=30 \
target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no \
host-key-size=2048 strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=8k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=\
yes packets=yes protocol=yes src-address=yes src-address-mask=yes \
src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes \
tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public \
trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=Africa/Johannesburg
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=\
bootp force-backup-booter=no protected-routerboot=disabled \
reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard mode-button
set enabled=no on-event=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m ping-timeout=1m \
watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
filter-interface="" filter-ip-address="" filter-ip-protocol="" \
filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" \
filter-operator-between-entries=or filter-port="" filter-stream=no \
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes \
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
