Fritzbox and MikroTik
how can I migrate the MikroTik (RB2011UiAS-2HnD-IN) router into the net of my FritzBox? Is it possible that I can access from a Client in my Mikrotik-net a Windows share in the FritzBox net?
push
This is mikrotik forum. Maybe none enough familiar with fritz box is here to answer your question. Generally speaking you can access everything thru the mikrotik. Depending on how you set it, of course.
I don’t understand the question.
Simply plug in your miktoritk device in your network.
Ether1 → Master
Other Ports Slave with Ether1 as Master and you can use it as simple swtich.
