Hey.
I’ve got config like this:
# 2024-02-03 19:53:48 by RouterOS 7.13.3
# software id = **ELIDED**
# model = C53UiG+5HPaxD2HPaxD
# serial number = **ELIDED**
add name=LAN
add name=WAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ac .frequency=5300 \
configuration.country=Poland .mode=ap .ssid=**ELIDED** disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=**ELIDED**
/interface wifi
set [ find default-name=wifi2 ] configuration.country=Poland .mode=ap .ssid=**ELIDED** disabled=no security=**ELIDED**
/interface wifi configuration
add chains="" country=Poland disabled=no mode=ap name=#conf_2.4GHZ security=**ELIDED** ssid=**ELIDED**
add name=LAN_DHCP ranges=192.168.0.2-192.168.0.254
add address-pool=LAN_DHCP interface=LAN name=LAN_DHCP
add bridge=WAN interface=ether1
add bridge=LAN interface=ether2
add bridge=LAN interface=ether3
add bridge=LAN interface=ether4
add bridge=LAN interface=wifi1
add bridge=LAN interface=wifi2
add address=192.168.0.1/24 interface=LAN network=192.168.0.0
/ip cloud
set update-time=no
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add interface=ether1
add address=192.168.0.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.0.1 \
netmask=24
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=masquerade chain=srcnat out-interface=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
How to fix log:
temporary moving client ether1 from slave to master port, update your config!!!
