from switch to server x86
i have Mikrotik on x86 HP DL server , one 4 port 10GB SFP+ intel and one 2 port 40GB QSFP HPE and they are working great, but connecting with other isp ( 10-20KM link) i have problem with sfp modules, because intel is using some different and are not compatible with Mikrotik.
i have also CRS 24 SFP+ mikrotik switch and i using only 16 port there, so 8 port are free.
again let me explain: I get 4 fiber from ISP and i get 0.0.0.0/26 | 1.1.1.1/27 | 2.2.2.2/27 | 3.3.3.3/25 ( this im using with converters but only 1G)
i read that i can use MLAG to add ports first on swich and than routing on HPE X86 mikrotik.
i see this
https://help.mikrotik.com/docs/display/ROS/Multi-chassis+Link+Aggregation+Group
did someone try this, getting link firts in Mikrotik switch CRS3xx and than with DAC cable into Inetl sfp+ port and to get to work?
Thx
Mclag is non functional. Always has been.
so how can i make that working?
with LACP ore what to to?
if you understand me i need: fibre who is coming from ISP to punt in switch first, than with dac cable connecting in Mikrotik.
