levak
April 15, 2014, 8:57am
1
Hello!
I have to create a public wifi, where I will be able to keep track of when someone access internet through my wifi (organization’s demands).
So here is how I’m thinking of doing it:
collect personal ID from client
enter name and surname of client in a html frontend page
send that data to user manager, create a new user
user manager returns username and password for hotspot
I print the voucher with 2h limit
client logs on the network
it would be ideal if the system could also log user MAC as well…
Is that doable?
How hard is it?
Any examples online?
What search terms should I look at?
Matej
levak
April 15, 2014, 9:04am
3
I myself would use it, but I want to make a “idiot proof” system that will be used by the employees, which are affraid of every new thing and god forbid that there is one form that doesn’t need to be filled:)
I want to make is as simple as possible for them to use:
Enter data
Click Send
Wait for refreshed page with username / password
Print voucher
Actually, I could probably merge step 3 and 4 together:)
Matej
I NOT USE API, do not ask me for support, use the forum.
You can write your own php page, and with API do all you want…
levak
April 15, 2014, 10:18am
5
Don’t worry, I wont ask you:)
I will take a look at the API and try to do something useful:)
Is it possible to host the web page on the Mikrotik router?
Matej
levak:
Matej
No, only external webserver.
need this solution on this post, have you been able to achieve the solution to this problem?
I hope that levak leave us informed.
levak
April 15, 2014, 12:37pm
9
I’m planning to look into that, but not sure when. I have other projects before that, but I will keep you posted about my progress…
Matej
levak:
Enter data
Click Send
Print voucher
Matej
If you’re not stuck with User Manager and are OK with hosting on external server, Access Manager(http://accessmanager.in ) may fit your requirement.
