"Frozen" health values 7.2.3 and 7.3 wap ac
Version:
[admin@router] > /system/package/print
Columns: NAME, VERSION
# NAME      VERSION
0 routeros  7.2.3
1 iot       7.2.3
Same behavior with 7.3
Router’s model:
[admin@router] /system/routerboard> /system/routerboard/print
       routerboard: yes
        board-name: wAP ac
             model: RBwAPG-5HacD2HnD
          revision: r3
     serial-number: XXXXXXXXXXXX
     firmware-type: ipq4000L
  factory-firmware: 6.44.6
  current-firmware: 7.2.3
  upgrade-firmware: 7.2.3
Steps to reproduce the issue:
Script:
# Required packages: iot
############################## Time function ##################################
:global EpochTime do={
 :local ds [/system clock get date];
 :local dst [/system/clock/ get dst-active];
 :local dstShift;
 :local months;
 :if ($dst = true) do={
    :set dstShift 14400;
 } else={
    :set dstShift 18000;
 :if ((([:pick $ds 9 11]-1)/4) != (([:pick $ds 9 11])/4)) do={
    :set months {"an"=0;"eb"=31;"ar"=60;"pr"=91;"ay"=121;"un"=152;"ul"=182;"ug"=213;"ep"=244;"ct"=274;"ov"=305;"ec"=335};
 } else={
    :set months {"an"=0;"eb"=31;"ar"=59;"pr"=90;"ay"=120;"un"=151;"ul"=181;"ug"=212;"ep"=243;"ct"=273;"ov"=304;"ec"=334};
 :set ds (([:pick $ds 9 11]*365)+(([:pick $ds 9 11]-1)/4)+($months->[:pick $ds 1 3])+[:pick $ds 4 6]);
 :local ts [/system clock get time];
 :set ts (([:pick $ts 0 2]*60*60)+([:pick $ts 3 5]*60)+[:pick $ts 6 8]);
 :return ($ds*24*60*60 + $ts + 946684800 + $dstShift);
################################ Configuration ################################
# Name of an existing MQTT broker that should be used for publishing
:local broker "MQTT"
# MQTT topic where the message should be published
:local topic "topic"
#################################### System ###################################
:put ("[*] Gathering system info...")
:local voltage [/system health get *d value]
:local temperature [/system health get *e value]
:local upTime [/system resource get uptime]
:local epoch [ $EpochTime ];
#################################### MQTT #####################################
:local message \
    "{\"time\": $epoch,\
      \"voltage_router\": $voltage,\
      \"temperature_router\": $temperature}"
#      \"temperature_router\":\"$temperature\",\
#      \"uptime\":\"$upTime\"}"
:log info "$message";
/iot mqtt publish broker=$broker topic=$topic message=$message
Scheduled to run every 1 minute.
Temperature change over the 24 hours window is around 5-15 C.
Positive case: When Winbox is connected to the router temperate values are changing and showing more or less adequate values.
Negative case: When Winbox is disconnected temperature values are showing same (“frozen”) numbers for long period of time (days). No drift at all.
Proof:
 02:31:00 script,info {"time": 1654065060,"voltage_router": 12.8,"temperature_router": 37}
 02:32:00 script,info {"time": 1654065120,"voltage_router": 12.8,"temperature_router": 37}
 02:33:00 script,info {"time": 1654065180,"voltage_router": 12.8,"temperature_router": 37}
 02:34:00 script,info {"time": 1654065240,"voltage_router": 12.8,"temperature_router": 37}
 02:35:00 script,info {"time": 1654065300,"voltage_router": 12.8,"temperature_router": 37}
 02:36:00 script,info {"time": 1654065360,"voltage_router": 12.8,"temperature_router": 37}
 02:37:00 script,info {"time": 1654065420,"voltage_router": 12.8,"temperature_router": 37}
 02:38:00 script,info {"time": 1654065480,"voltage_router": 12.8,"temperature_router": 37}
 02:39:00 script,info {"time": 1654065540,"voltage_router": 12.8,"temperature_router": 37}
 02:40:00 script,info {"time": 1654065600,"voltage_router": 12.8,"temperature_router": 37}
 02:41:00 script,info {"time": 1654065660,"voltage_router": 12.8,"temperature_router": 37}
 02:42:00 script,info {"time": 1654065720,"voltage_router": 12.8,"temperature_router": 37}
 02:43:00 script,info {"time": 1654065780,"voltage_router": 12.8,"temperature_router": 37}
 02:44:00 script,info {"time": 1654065840,"voltage_router": 12.8,"temperature_router": 37}
 02:45:00 script,info {"time": 1654065900,"voltage_router": 12.8,"temperature_router": 37}
 02:46:00 script,info {"time": 1654065960,"voltage_router": 12.8,"temperature_router": 37}
 02:47:00 script,info {"time": 1654066020,"voltage_router": 12.8,"temperature_router": 37}
 02:48:00 script,info {"time": 1654066080,"voltage_router": 12.8,"temperature_router": 37}
 02:49:00 script,info {"time": 1654066140,"voltage_router": 12.8,"temperature_router": 37}
 02:50:00 script,info {"time": 1654066200,"voltage_router": 12.8,"temperature_router": 37}
 02:51:00 script,info {"time": 1654066260,"voltage_router": 12.8,"temperature_router": 37}
 02:52:00 script,info {"time": 1654066320,"voltage_router": 12.8,"temperature_router": 37}
 02:53:00 script,info {"time": 1654066380,"voltage_router": 12.8,"temperature_router": 37}
 02:54:00 script,info {"time": 1654066440,"voltage_router": 12.8,"temperature_router": 37}
 02:55:00 script,info {"time": 1654066500,"voltage_router": 12.8,"temperature_router": 37}
 02:56:00 script,info {"time": 1654066560,"voltage_router": 12.8,"temperature_router": 37}
 02:57:00 script,info {"time": 1654066620,"voltage_router": 12.8,"temperature_router": 37}
 02:58:00 script,info {"time": 1654066680,"voltage_router": 12.8,"temperature_router": 37}
 02:59:00 script,info {"time": 1654066740,"voltage_router": 12.8,"temperature_router": 37}
 03:00:00 script,info {"time": 1654066800,"voltage_router": 12.8,"temperature_router": 37}
 03:01:00 script,info {"time": 1654066860,"voltage_router": 12.8,"temperature_router": 37}
 03:02:00 script,info {"time": 1654066920,"voltage_router": 12.8,"temperature_router": 37}
 03:03:00 script,info {"time": 1654066980,"voltage_router": 12.8,"temperature_router": 37}
 03:04:00 script,info {"time": 1654067040,"voltage_router": 12.8,"temperature_router": 37}
 03:05:00 script,info {"time": 1654067100,"voltage_router": 12.8,"temperature_router": 37}
 03:06:00 script,info {"time": 1654067160,"voltage_router": 12.8,"temperature_router": 37}
 03:07:00 script,info {"time": 1654067220,"voltage_router": 12.8,"temperature_router": 37}
 03:08:00 script,info {"time": 1654067280,"voltage_router": 12.8,"temperature_router": 37}
 03:09:00 script,info {"time": 1654067340,"voltage_router": 12.8,"temperature_router": 37}
 03:10:00 script,info {"time": 1654067400,"voltage_router": 12.8,"temperature_router": 37}
 03:11:00 script,info {"time": 1654067460,"voltage_router": 12.8,"temperature_router": 37}
 03:12:00 script,info {"time": 1654067520,"voltage_router": 12.8,"temperature_router": 37}
 03:13:00 script,info {"time": 1654067580,"voltage_router": 12.8,"temperature_router": 37}
 03:14:00 script,info {"time": 1654067640,"voltage_router": 12.8,"temperature_router": 37}
 03:15:00 script,info {"time": 1654067700,"voltage_router": 12.8,"temperature_router": 37}
 03:16:00 script,info {"time": 1654067760,"voltage_router": 12.8,"temperature_router": 37}
 03:17:00 script,info {"time": 1654067820,"voltage_router": 12.8,"temperature_router": 37}
 03:18:00 script,info {"time": 1654067880,"voltage_router": 12.8,"temperature_router": 37}
 03:19:00 script,info {"time": 1654067940,"voltage_router": 12.8,"temperature_router": 37}
 03:20:00 script,info {"time": 1654068000,"voltage_router": 12.8,"temperature_router": 37}
 03:22:00 script,info {"time": 1654068120,"voltage_router": 12.8,"temperature_router": 37}
 03:23:00 script,info {"time": 1654068180,"voltage_router": 12.8,"temperature_router": 37}
 03:24:00 script,info {"time": 1654068240,"voltage_router": 12.8,"temperature_router": 37}
 03:25:00 script,info {"time": 1654068300,"voltage_router": 12.8,"temperature_router": 37}
 03:26:00 script,info {"time": 1654068360,"voltage_router": 12.8,"temperature_router": 37}
 03:27:00 script,info {"time": 1654068420,"voltage_router": 12.8,"temperature_router": 37}
 03:28:00 script,info {"time": 1654068480,"voltage_router": 12.8,"temperature_router": 37}
 03:29:00 script,info {"time": 1654068540,"voltage_router": 12.8,"temperature_router": 37}
 03:30:00 script,info {"time": 1654068600,"voltage_router": 12.8,"temperature_router": 37}
 03:31:00 script,info {"time": 1654068660,"voltage_router": 12.8,"temperature_router": 37}
 03:32:00 script,info {"time": 1654068720,"voltage_router": 12.8,"temperature_router": 37}
 03:33:00 script,info {"time": 1654068780,"voltage_router": 12.8,"temperature_router": 37}
 03:34:00 script,info {"time": 1654068840,"voltage_router": 12.8,"temperature_router": 37}
 03:35:00 script,info {"time": 1654068900,"voltage_router": 12.8,"temperature_router": 37}
 03:36:00 script,info {"time": 1654068960,"voltage_router": 12.8,"temperature_router": 37}
 03:37:00 script,info {"time": 1654069020,"voltage_router": 12.8,"temperature_router": 37}
 03:38:00 script,info {"time": 1654069080,"voltage_router": 12.8,"temperature_router": 37}
 03:39:00 script,info {"time": 1654069140,"voltage_router": 12.8,"temperature_router": 37}
 03:40:00 script,info {"time": 1654069200,"voltage_router": 12.8,"temperature_router": 37}
 03:41:00 script,info {"time": 1654069260,"voltage_router": 12.8,"temperature_router": 37}
 03:42:00 script,info {"time": 1654069320,"voltage_router": 12.8,"temperature_router": 37}
 03:43:00 script,info {"time": 1654069380,"voltage_router": 12.8,"temperature_router": 37}
 03:44:00 script,info {"time": 1654069440,"voltage_router": 12.8,"temperature_router": 37}
 03:45:00 script,info {"time": 1654069500,"voltage_router": 12.8,"temperature_router": 37}
 03:46:00 script,info {"time": 1654069560,"voltage_router": 12.8,"temperature_router": 37}
 03:47:00 script,info {"time": 1654069620,"voltage_router": 12.8,"temperature_router": 37}
 03:48:00 script,info {"time": 1654069680,"voltage_router": 12.8,"temperature_router": 37}
 03:49:00 script,info {"time": 1654069740,"voltage_router": 12.8,"temperature_router": 37}
 03:50:00 script,info {"time": 1654069800,"voltage_router": 12.8,"temperature_router": 37}
 03:51:00 script,info {"time": 1654069860,"voltage_router": 12.8,"temperature_router": 37}
 03:52:00 script,info {"time": 1654069920,"voltage_router": 12.8,"temperature_router": 37}
 03:53:00 script,info {"time": 1654069980,"voltage_router": 12.8,"temperature_router": 37}
 03:54:00 script,info {"time": 1654070040,"voltage_router": 12.8,"temperature_router": 37}
 03:55:00 script,info {"time": 1654070100,"voltage_router": 12.8,"temperature_router": 37}
 03:56:00 script,info {"time": 1654070160,"voltage_router": 12.8,"temperature_router": 37}
 03:57:00 script,info {"time": 1654070220,"voltage_router": 12.8,"temperature_router": 37}
 03:58:00 script,info {"time": 1654070280,"voltage_router": 12.8,"temperature_router": 37}
 03:59:00 script,info {"time": 1654070340,"voltage_router": 12.8,"temperature_router": 37}
 04:00:00 script,info {"time": 1654070400,"voltage_router": 12.8,"temperature_router": 37}
 04:01:00 script,info {"time": 1654070460,"voltage_router": 12.8,"temperature_router": 37}
 04:02:00 script,info {"time": 1654070520,"voltage_router": 12.8,"temperature_router": 37}
 04:03:00 script,info {"time": 1654070580,"voltage_router": 12.8,"temperature_router": 37}
 04:04:00 script,info {"time": 1654070640,"voltage_router": 12.8,"temperature_router": 37}
 04:05:00 script,info {"time": 1654070700,"voltage_router": 12.8,"temperature_router": 37}
 04:06:00 script,info {"time": 1654070760,"voltage_router": 12.8,"temperature_router": 37}
 04:07:00 script,info {"time": 1654070820,"voltage_router": 12.8,"temperature_router": 37}
 04:08:00 script,info {"time": 1654070880,"voltage_router": 12.8,"temperature_router": 37}
 04:09:00 script,info {"time": 1654070940,"voltage_router": 12.8,"temperature_router": 37}
 04:10:00 script,info {"time": 1654071000,"voltage_router": 12.8,"temperature_router": 37}
 04:11:00 script,info {"time": 1654071060,"voltage_router": 12.8,"temperature_router": 37}
 04:12:00 script,info {"time": 1654071120,"voltage_router": 12.8,"temperature_router": 37}
 04:13:00 script,info {"time": 1654071180,"voltage_router": 12.8,"temperature_router": 37}
 04:14:00 script,info {"time": 1654071240,"voltage_router": 12.8,"temperature_router": 37}
 04:15:00 script,info {"time": 1654071300,"voltage_router": 12.8,"temperature_router": 37}
 04:16:00 script,info {"time": 1654071360,"voltage_router": 12.8,"temperature_router": 37}
 04:17:00 script,info {"time": 1654071420,"voltage_router": 12.8,"temperature_router": 37}
 04:18:00 script,info {"time": 1654071480,"voltage_router": 12.8,"temperature_router": 37}
 04:19:00 script,info {"time": 1654071540,"voltage_router": 12.8,"temperature_router": 37}
 04:20:00 script,info {"time": 1654071600,"voltage_router": 12.8,"temperature_router": 37}
 04:21:00 script,info {"time": 1654071660,"voltage_router": 12.8,"temperature_router": 37}
 04:22:00 script,info {"time": 1654071720,"voltage_router": 12.8,"temperature_router": 37}
 04:23:00 script,info {"time": 1654071780,"voltage_router": 12.8,"temperature_router": 37}
 04:24:00 script,info {"time": 1654071840,"voltage_router": 12.8,"temperature_router": 37}
 04:25:00 script,info {"time": 1654071900,"voltage_router": 12.8,"temperature_router": 37}
 04:26:00 script,info {"time": 1654071960,"voltage_router": 12.8,"temperature_router": 37}
 04:27:00 script,info {"time": 1654072020,"voltage_router": 12.8,"temperature_router": 37}
 04:28:00 script,info {"time": 1654072080,"voltage_router": 12.8,"temperature_router": 37}
 04:29:00 script,info {"time": 1654072140,"voltage_router": 12.8,"temperature_router": 37}
 04:30:00 script,info {"time": 1654072200,"voltage_router": 12.8,"temperature_router": 37}
 04:31:00 script,info {"time": 1654072260,"voltage_router": 12.8,"temperature_router": 37}
 04:32:00 script,info {"time": 1654072320,"voltage_router": 12.8,"temperature_router": 37}
 04:33:00 script,info {"time": 1654072380,"voltage_router": 12.8,"temperature_router": 37}
 04:34:00 script,info {"time": 1654072440,"voltage_router": 12.8,"temperature_router": 37}
 04:35:00 script,info {"time": 1654072500,"voltage_router": 12.8,"temperature_router": 37}
 04:36:00 script,info {"time": 1654072560,"voltage_router": 12.8,"temperature_router": 37}
 04:37:00 script,info {"time": 1654072620,"voltage_router": 12.8,"temperature_router": 37}
 04:38:00 script,info {"time": 1654072680,"voltage_router": 12.8,"temperature_router": 37}
 04:39:00 script,info {"time": 1654072740,"voltage_router": 12.8,"temperature_router": 37}
 04:40:00 script,info {"time": 1654072800,"voltage_router": 12.8,"temperature_router": 37}
 04:41:00 script,info {"time": 1654072860,"voltage_router": 12.8,"temperature_router": 37}
 04:42:00 script,info {"time": 1654072920,"voltage_router": 12.8,"temperature_router": 37}
 04:43:00 script,info {"time": 1654072980,"voltage_router": 12.8,"temperature_router": 37}
 04:44:00 script,info {"time": 1654073040,"voltage_router": 12.8,"temperature_router": 37}
 04:45:00 script,info {"time": 1654073100,"voltage_router": 12.8,"temperature_router": 37}
 04:46:00 script,info {"time": 1654073160,"voltage_router": 12.8,"temperature_router": 37}
 04:47:00 script,info {"time": 1654073220,"voltage_router": 12.8,"temperature_router": 37}
 04:48:00 script,info {"time": 1654073280,"voltage_router": 12.8,"temperature_router": 37}
 04:49:00 script,info {"time": 1654073340,"voltage_router": 12.8,"temperature_router": 37}
 04:50:00 script,info {"time": 1654073400,"voltage_router": 12.8,"temperature_router": 37}
 04:51:00 script,info {"time": 1654073460,"voltage_router": 12.8,"temperature_router": 37}
 04:52:00 script,info {"time": 1654073520,"voltage_router": 12.8,"temperature_router": 37}
 04:53:00 script,info {"time": 1654073580,"voltage_router": 12.8,"temperature_router": 37}
 04:54:00 script,info {"time": 1654073640,"voltage_router": 12.8,"temperature_router": 37}
 04:55:00 script,info {"time": 1654073700,"voltage_router": 12.8,"temperature_router": 37}
 04:56:00 script,info {"time": 1654073760,"voltage_router": 12.8,"temperature_router": 37}
 04:57:00 script,info {"time": 1654073820,"voltage_router": 12.8,"temperature_router": 37}
 04:58:00 script,info {"time": 1654073880,"voltage_router": 12.8,"temperature_router": 37}
 04:59:00 script,info {"time": 1654073940,"voltage_router": 12.8,"temperature_router": 37}
 05:00:00 script,info {"time": 1654074000,"voltage_router": 12.8,"temperature_router": 37}
 05:01:00 script,info {"time": 1654074060,"voltage_router": 12.8,"temperature_router": 37}
 05:02:00 script,info {"time": 1654074120,"voltage_router": 12.8,"temperature_router": 37}
 05:03:00 script,info {"time": 1654074180,"voltage_router": 12.8,"temperature_router": 37}
 05:04:00 script,info {"time": 1654074240,"voltage_router": 12.8,"temperature_router": 37}
 05:05:00 script,info {"time": 1654074300,"voltage_router": 12.8,"temperature_router": 37}
 05:06:00 script,info {"time": 1654074360,"voltage_router": 12.8,"temperature_router": 37}
 05:07:00 script,info {"time": 1654074420,"voltage_router": 12.8,"temperature_router": 37}
 05:08:00 script,info {"time": 1654074480,"voltage_router": 12.8,"temperature_router": 37}
 05:09:00 script,info {"time": 1654074540,"voltage_router": 12.8,"temperature_router": 37}
 05:10:00 script,info {"time": 1654074600,"voltage_router": 12.8,"temperature_router": 37}
 05:11:00 script,info {"time": 1654074660,"voltage_router": 12.8,"temperature_router": 37}
 05:12:00 script,info {"time": 1654074720,"voltage_router": 12.8,"temperature_router": 37}
 05:13:00 script,info {"time": 1654074780,"voltage_router": 12.8,"temperature_router": 37}
 05:14:00 script,info {"time": 1654074840,"voltage_router": 12.8,"temperature_router": 37}
 05:15:00 script,info {"time": 1654074900,"voltage_router": 12.8,"temperature_router": 37}
 05:16:00 script,info {"time": 1654074960,"voltage_router": 12.8,"temperature_router": 37}
 05:17:00 script,info {"time": 1654075020,"voltage_router": 12.8,"temperature_router": 37}
 05:18:00 script,info {"time": 1654075080,"voltage_router": 12.8,"temperature_router": 37}
 05:19:00 script,info {"time": 1654075140,"voltage_router": 12.8,"temperature_router": 37}
 05:20:00 script,info {"time": 1654075200,"voltage_router": 12.8,"temperature_router": 37}
 05:21:00 script,info {"time": 1654075260,"voltage_router": 12.8,"temperature_router": 37}
 05:22:00 script,info {"time": 1654075320,"voltage_router": 12.8,"temperature_router": 37}
 05:23:00 script,info {"time": 1654075380,"voltage_router": 12.8,"temperature_router": 37}
 05:24:00 script,info {"time": 1654075440,"voltage_router": 12.8,"temperature_router": 37}
 05:25:00 script,info {"time": 1654075500,"voltage_router": 12.8,"temperature_router": 37}
 05:26:00 script,info {"time": 1654075560,"voltage_router": 12.8,"temperature_router": 37}
 05:27:00 script,info {"time": 1654075620,"voltage_router": 12.8,"temperature_router": 37}
 05:28:00 script,info {"time": 1654075680,"voltage_router": 12.8,"temperature_router": 37}
 05:29:00 script,info {"time": 1654075740,"voltage_router": 12.8,"temperature_router": 37}
 05:30:00 script,info {"time": 1654075800,"voltage_router": 12.8,"temperature_router": 37}
 05:31:00 script,info {"time": 1654075860,"voltage_router": 12.8,"temperature_router": 37}
 05:32:00 script,info {"time": 1654075920,"voltage_router": 12.8,"temperature_router": 37}
 05:33:00 script,info {"time": 1654075980,"voltage_router": 12.8,"temperature_router": 37}
 05:34:00 script,info {"time": 1654076040,"voltage_router": 12.8,"temperature_router": 37}
 05:35:00 script,info {"time": 1654076100,"voltage_router": 12.8,"temperature_router": 37}
 05:36:00 script,info {"time": 1654076160,"voltage_router": 12.8,"temperature_router": 37}
 05:37:00 script,info {"time": 1654076220,"voltage_router": 12.8,"temperature_router": 37}
 05:38:00 script,info {"time": 1654076280,"voltage_router": 12.8,"temperature_router": 37}
 05:39:00 script,info {"time": 1654076340,"voltage_router": 12.8,"temperature_router": 37}
 05:40:00 script,info {"time": 1654076400,"voltage_router": 12.8,"temperature_router": 37}
 05:41:00 script,info {"time": 1654076460,"voltage_router": 12.8,"temperature_router": 37}
 05:42:00 script,info {"time": 1654076520,"voltage_router": 12.8,"temperature_router": 37}
 05:43:00 script,info {"time": 1654076580,"voltage_router": 12.8,"temperature_router": 37}
 05:44:00 script,info {"time": 1654076640,"voltage_router": 12.8,"temperature_router": 37}
 05:45:00 script,info {"time": 1654076700,"voltage_router": 12.8,"temperature_router": 37}
 05:46:00 script,info {"time": 1654076760,"voltage_router": 12.8,"temperature_router": 37}
 05:47:00 script,info {"time": 1654076820,"voltage_router": 12.8,"temperature_router": 37}
 05:48:00 script,info {"time": 1654076880,"voltage_router": 12.8,"temperature_router": 37}
 05:49:00 script,info {"time": 1654076940,"voltage_router": 12.8,"temperature_router": 37}
 05:50:00 script,info {"time": 1654077000,"voltage_router": 12.8,"temperature_router": 37}
 05:51:00 script,info {"time": 1654077060,"voltage_router": 12.8,"temperature_router": 37}
 05:52:00 script,info {"time": 1654077120,"voltage_router": 12.8,"temperature_router": 37}
 05:53:00 script,info {"time": 1654077180,"voltage_router": 12.8,"temperature_router": 37}
 05:54:00 script,info {"time": 1654077240,"voltage_router": 12.8,"temperature_router": 37}
 05:55:00 script,info {"time": 1654077300,"voltage_router": 12.8,"temperature_router": 37}
 05:56:00 script,info {"time": 1654077360,"voltage_router": 12.8,"temperature_router": 37}
 05:57:00 script,info {"time": 1654077420,"voltage_router": 12.8,"temperature_router": 37}
 05:58:00 script,info {"time": 1654077480,"voltage_router": 12.8,"temperature_router": 37}
 05:59:00 script,info {"time": 1654077540,"voltage_router": 12.8,"temperature_router": 37}
 06:00:00 script,info {"time": 1654077600,"voltage_router": 12.8,"temperature_router": 37}
 06:01:00 script,info {"time": 1654077660,"voltage_router": 12.8,"temperature_router": 37}
 06:02:00 script,info {"time": 1654077720,"voltage_router": 12.8,"temperature_router": 37}
 06:03:00 script,info {"time": 1654077780,"voltage_router": 12.8,"temperature_router": 37}
 06:04:00 script,info {"time": 1654077840,"voltage_router": 12.8,"temperature_router": 37}
 06:05:00 script,info {"time": 1654077900,"voltage_router": 12.8,"temperature_router": 37}
 06:06:00 script,info {"time": 1654077960,"voltage_router": 12.8,"temperature_router": 37}
 06:07:00 script,info {"time": 1654078020,"voltage_router": 12.8,"temperature_router": 37}
 06:08:00 script,info {"time": 1654078080,"voltage_router": 12.8,"temperature_router": 37}
 06:09:00 script,info {"time": 1654078140,"voltage_router": 12.8,"temperature_router": 37}
 06:10:00 script,info {"time": 1654078200,"voltage_router": 12.8,"temperature_router": 37}
 06:11:00 script,info {"time": 1654078260,"voltage_router": 12.8,"temperature_router": 37}
 06:12:00 script,info {"time": 1654078320,"voltage_router": 12.8,"temperature_router": 37}
 06:13:00 script,info {"time": 1654078380,"voltage_router": 12.8,"temperature_router": 37}
 06:14:00 script,info {"time": 1654078440,"voltage_router": 12.8,"temperature_router": 37}
 06:15:00 script,info {"time": 1654078500,"voltage_router": 12.8,"temperature_router": 37}
 06:16:00 script,info {"time": 1654078560,"voltage_router": 12.8,"temperature_router": 37}
 06:17:00 script,info {"time": 1654078620,"voltage_router": 12.8,"temperature_router": 37}
 06:18:00 script,info {"time": 1654078680,"voltage_router": 12.8,"temperature_router": 37}
 06:19:00 script,info {"time": 1654078740,"voltage_router": 12.8,"temperature_router": 37}
 06:20:00 script,info {"time": 1654078800,"voltage_router": 12.8,"temperature_router": 37}
 06:21:00 script,info {"time": 1654078860,"voltage_router": 12.8,"temperature_router": 37}
 06:22:00 script,info {"time": 1654078920,"voltage_router": 12.8,"temperature_router": 37}
 06:23:00 script,info {"time": 1654078980,"voltage_router": 12.8,"temperature_router": 37}
 06:24:00 script,info {"time": 1654079040,"voltage_router": 12.8,"temperature_router": 37}
 06:25:00 script,info {"time": 1654079100,"voltage_router": 12.8,"temperature_router": 37}
 06:26:00 script,info {"time": 1654079160,"voltage_router": 12.8,"temperature_router": 37}
 06:27:00 script,info {"time": 1654079220,"voltage_router": 12.8,"temperature_router": 37}
 06:28:00 script,info {"time": 1654079280,"voltage_router": 12.8,"temperature_router": 37}
 06:29:00 script,info {"time": 1654079340,"voltage_router": 12.8,"temperature_router": 37}
 06:30:00 script,info {"time": 1654079400,"voltage_router": 12.8,"temperature_router": 37}
 06:31:00 script,info {"time": 1654079460,"voltage_router": 12.8,"temperature_router": 37}
 06:32:00 script,info {"time": 1654079520,"voltage_router": 12.8,"temperature_router": 37}
 06:33:00 script,info {"time": 1654079580,"voltage_router": 12.8,"temperature_router": 37}
 06:34:00 script,info {"time": 1654079640,"voltage_router": 12.8,"temperature_router": 37}
 06:35:00 script,info {"time": 1654079700,"voltage_router": 12.8,"temperature_router": 37}
 06:36:00 script,info {"time": 1654079760,"voltage_router": 12.8,"temperature_router": 37}
 06:37:00 script,info {"time": 1654079820,"voltage_router": 12.8,"temperature_router": 37}
 06:38:00 script,info {"time": 1654079880,"voltage_router": 12.8,"temperature_router": 37}
 06:39:00 script,info {"time": 1654079940,"voltage_router": 12.8,"temperature_router": 37}
 06:40:00 script,info {"time": 1654080000,"voltage_router": 12.8,"temperature_router": 37}
 06:41:00 script,info {"time": 1654080060,"voltage_router": 12.8,"temperature_router": 37}
 06:42:00 script,info {"time": 1654080120,"voltage_router": 12.8,"temperature_router": 37}
 06:43:00 script,info {"time": 1654080180,"voltage_router": 12.8,"temperature_router": 37}
 06:44:00 script,info {"time": 1654080240,"voltage_router": 12.8,"temperature_router": 37}
 06:45:00 script,info {"time": 1654080300,"voltage_router": 12.8,"temperature_router": 37}
 06:46:00 script,info {"time": 1654080360,"voltage_router": 12.8,"temperature_router": 37}
 06:47:00 script,info {"time": 1654080420,"voltage_router": 12.8,"temperature_router": 37}
 06:48:00 script,info {"time": 1654080480,"voltage_router": 12.8,"temperature_router": 37}
 06:49:00 script,info {"time": 1654080540,"voltage_router": 12.8,"temperature_router": 37}
 06:50:00 script,info {"time": 1654080600,"voltage_router": 12.8,"temperature_router": 37}
 06:51:00 script,info {"time": 1654080660,"voltage_router": 12.8,"temperature_router": 37}
 06:52:00 script,info {"time": 1654080720,"voltage_router": 12.8,"temperature_router": 37}
 06:53:00 script,info {"time": 1654080780,"voltage_router": 12.8,"temperature_router": 37}
 06:54:00 script,info {"time": 1654080840,"voltage_router": 12.8,"temperature_router": 37}
 06:55:00 script,info {"time": 1654080900,"voltage_router": 12.8,"temperature_router": 37}
 06:56:00 script,info {"time": 1654080960,"voltage_router": 12.8,"temperature_router": 37}
 06:57:00 script,info {"time": 1654081020,"voltage_router": 12.8,"temperature_router": 37}
 06:58:00 script,info {"time": 1654081080,"voltage_router": 12.8,"temperature_router": 37}
 06:59:00 script,info {"time": 1654081140,"voltage_router": 12.8,"temperature_router": 37}
 07:00:00 script,info {"time": 1654081200,"voltage_router": 12.8,"temperature_router": 37}
 07:01:00 script,info {"time": 1654081260,"voltage_router": 12.8,"temperature_router": 37}
 07:02:00 script,info {"time": 1654081320,"voltage_router": 12.8,"temperature_router": 37}
 07:03:00 script,info {"time": 1654081380,"voltage_router": 12.8,"temperature_router": 37}
 07:04:00 script,info {"time": 1654081440,"voltage_router": 12.8,"temperature_router": 37}
 07:05:00 script,info {"time": 1654081500,"voltage_router": 12.8,"temperature_router": 37}
 07:06:00 script,info {"time": 1654081560,"voltage_router": 12.8,"temperature_router": 37}
 07:07:00 script,info {"time": 1654081620,"voltage_router": 12.8,"temperature_router": 37}
 07:08:00 script,info {"time": 1654081680,"voltage_router": 12.8,"temperature_router": 37}
 07:09:00 script,info {"time": 1654081740,"voltage_router": 12.8,"temperature_router": 37}
 07:10:00 script,info {"time": 1654081800,"voltage_router": 12.8,"temperature_router": 37}
 07:11:00 script,info {"time": 1654081860,"voltage_router": 12.8,"temperature_router": 37}
 07:12:00 script,info {"time": 1654081920,"voltage_router": 12.8,"temperature_router": 37}
 07:13:00 script,info {"time": 1654081980,"voltage_router": 12.8,"temperature_router": 37}
 07:14:00 script,info {"time": 1654082040,"voltage_router": 12.8,"temperature_router": 37}
 07:15:00 script,info {"time": 1654082100,"voltage_router": 12.8,"temperature_router": 37}
 07:16:00 script,info {"time": 1654082160,"voltage_router": 12.8,"temperature_router": 37}
 07:17:00 script,info {"time": 1654082220,"voltage_router": 12.8,"temperature_router": 37}
 07:18:00 script,info {"time": 1654082280,"voltage_router": 12.8,"temperature_router": 37}
 07:19:00 script,info {"time": 1654082340,"voltage_router": 12.8,"temperature_router": 37}
 07:20:00 script,info {"time": 1654082400,"voltage_router": 12.8,"temperature_router": 37}
 07:21:00 script,info {"time": 1654082460,"voltage_router": 12.8,"temperature_router": 37}
 07:22:00 script,info {"time": 1654082520,"voltage_router": 12.8,"temperature_router": 37}
 07:23:00 script,info {"time": 1654082580,"voltage_router": 12.8,"temperature_router": 37}
 07:24:00 script,info {"time": 1654082640,"voltage_router": 12.8,"temperature_router": 37}
 07:25:00 script,info {"time": 1654082700,"voltage_router": 12.8,"temperature_router": 37}
 07:26:00 script,info {"time": 1654082760,"voltage_router": 12.8,"temperature_router": 37}
 07:27:00 script,info {"time": 1654082820,"voltage_router": 12.8,"temperature_router": 37}
 07:28:00 script,info {"time": 1654082880,"voltage_router": 12.8,"temperature_router": 37}
 07:29:00 script,info {"time": 1654082940,"voltage_router": 12.8,"temperature_router": 37}
 07:30:00 script,info {"time": 1654083000,"voltage_router": 12.8,"temperature_router": 37}
 07:31:00 script,info {"time": 1654083060,"voltage_router": 12.8,"temperature_router": 37}
 07:32:00 script,info {"time": 1654083120,"voltage_router": 12.8,"temperature_router": 37}
 07:33:00 script,info {"time": 1654083180,"voltage_router": 12.8,"temperature_router": 37}
 07:34:00 script,info {"time": 1654083240,"voltage_router": 12.8,"temperature_router": 37}
 07:35:00 script,info {"time": 1654083300,"voltage_router": 12.8,"temperature_router": 37}
 07:36:00 script,info {"time": 1654083360,"voltage_router": 12.8,"temperature_router": 37}
 07:37:00 script,info {"time": 1654083420,"voltage_router": 12.8,"temperature_router": 37}
 07:38:00 script,info {"time": 1654083480,"voltage_router": 12.8,"temperature_router": 37}
 07:39:00 script,info {"time": 1654083540,"voltage_router": 12.8,"temperature_router": 37}
 07:40:00 script,info {"time": 1654083600,"voltage_router": 12.8,"temperature_router": 37}
 07:41:00 script,info {"time": 1654083660,"voltage_router": 12.8,"temperature_router": 37}
 07:42:00 script,info {"time": 1654083720,"voltage_router": 12.8,"temperature_router": 37}
 07:43:00 script,info {"time": 1654083780,"voltage_router": 12.8,"temperature_router": 37}
 07:44:00 script,info {"time": 1654083840,"voltage_router": 12.8,"temperature_router": 37}
 07:45:00 script,info {"time": 1654083900,"voltage_router": 12.8,"temperature_router": 37}
 07:46:00 script,info {"time": 1654083960,"voltage_router": 12.8,"temperature_router": 37}
 07:47:00 script,info {"time": 1654084020,"voltage_router": 12.8,"temperature_router": 37}
 07:48:00 script,info {"time": 1654084080,"voltage_router": 12.8,"temperature_router": 37}
 07:49:00 script,info {"time": 1654084140,"voltage_router": 12.8,"temperature_router": 37}
 07:50:00 script,info {"time": 1654084200,"voltage_router": 12.8,"temperature_router": 37}
 07:51:00 script,info {"time": 1654084260,"voltage_router": 12.8,"temperature_router": 37}
 07:52:00 script,info {"time": 1654084320,"voltage_router": 12.8,"temperature_router": 37}
 07:53:00 script,info {"time": 1654084380,"voltage_router": 12.8,"temperature_router": 37}
 07:54:00 script,info {"time": 1654084440,"voltage_router": 12.8,"temperature_router": 37}
 07:55:00 script,info {"time": 1654084500,"voltage_router": 12.8,"temperature_router": 37}
 07:56:00 script,info {"time": 1654084560,"voltage_router": 12.8,"temperature_router": 37}
 07:57:00 script,info {"time": 1654084620,"voltage_router": 12.8,"temperature_router": 37}
 07:58:00 script,info {"time": 1654084680,"voltage_router": 12.8,"temperature_router": 37}
 07:59:00 script,info {"time": 1654084740,"voltage_router": 12.8,"temperature_router": 37}
 08:00:00 script,info {"time": 1654084800,"voltage_router": 12.8,"temperature_router": 37}
 08:01:00 script,info {"time": 1654084860,"voltage_router": 12.8,"temperature_router": 37}
 08:02:00 script,info {"time": 1654084920,"voltage_router": 12.8,"temperature_router": 37}
 08:03:00 script,info {"time": 1654084980,"voltage_router": 12.8,"temperature_router": 37}
 08:04:00 script,info {"time": 1654085040,"voltage_router": 12.8,"temperature_router": 37}
 08:05:00 script,info {"time": 1654085100,"voltage_router": 12.8,"temperature_router": 37}
 08:06:00 script,info {"time": 1654085160,"voltage_router": 12.8,"temperature_router": 37}
 08:07:00 script,info {"time": 1654085220,"voltage_router": 12.8,"temperature_router": 37}
 08:08:00 script,info {"time": 1654085280,"voltage_router": 12.8,"temperature_router": 37}
 08:09:00 script,info {"time": 1654085340,"voltage_router": 12.8,"temperature_router": 37}
 08:10:00 script,info {"time": 1654085400,"voltage_router": 12.8,"temperature_router": 37}
 08:11:00 script,info {"time": 1654085460,"voltage_router": 12.8,"temperature_router": 37}
 08:12:00 script,info {"time": 1654085520,"voltage_router": 12.8,"temperature_router": 37}
 08:13:00 script,info {"time": 1654085580,"voltage_router": 12.8,"temperature_router": 37}
 08:14:00 script,info {"time": 1654085640,"voltage_router": 12.8,"temperature_router": 37}
 08:15:00 script,info {"time": 1654085700,"voltage_router": 12.8,"temperature_router": 37}
 08:16:00 script,info {"time": 1654085760,"voltage_router": 12.8,"temperature_router": 37}
 08:17:00 script,info {"time": 1654085820,"voltage_router": 12.8,"temperature_router": 37}
 08:18:00 script,info {"time": 1654085880,"voltage_router": 12.8,"temperature_router": 37}
 08:19:00 script,info {"time": 1654085940,"voltage_router": 12.8,"temperature_router": 37}
 08:20:00 script,info {"time": 1654086000,"voltage_router": 12.8,"temperature_router": 37}
 08:21:00 script,info {"time": 1654086060,"voltage_router": 12.8,"temperature_router": 37}
 08:22:00 script,info {"time": 1654086120,"voltage_router": 12.8,"temperature_router": 37}
 08:23:00 script,info {"time": 1654086180,"voltage_router": 12.8,"temperature_router": 37}
 08:24:00 script,info {"time": 1654086240,"voltage_router": 12.8,"temperature_router": 37}
 08:25:00 script,info {"time": 1654086300,"voltage_router": 12.8,"temperature_router": 37}
 08:26:00 script,info {"time": 1654086360,"voltage_router": 12.8,"temperature_router": 37}
 08:27:00 script,info {"time": 1654086420,"voltage_router": 12.8,"temperature_router": 37}
 08:28:00 script,info {"time": 1654086480,"voltage_router": 12.8,"temperature_router": 37}
 08:29:00 script,info {"time": 1654086540,"voltage_router": 12.8,"temperature_router": 37}
 08:30:00 script,info {"time": 1654086600,"voltage_router": 12.8,"temperature_router": 37}
 08:31:00 script,info {"time": 1654086660,"voltage_router": 12.8,"temperature_router": 37}
 08:32:00 script,info {"time": 1654086720,"voltage_router": 12.8,"temperature_router": 37}
 08:33:00 script,info {"time": 1654086780,"voltage_router": 12.8,"temperature_router": 37}
 08:34:00 script,info {"time": 1654086840,"voltage_router": 12.8,"temperature_router": 37}
 08:35:00 script,info {"time": 1654086900,"voltage_router": 12.8,"temperature_router": 37}
 08:36:00 script,info {"time": 1654086960,"voltage_router": 12.8,"temperature_router": 37}
 08:37:00 script,info {"time": 1654087020,"voltage_router": 12.8,"temperature_router": 37}
 08:38:00 script,info {"time": 1654087080,"voltage_router": 12.8,"temperature_router": 37}
 08:39:00 script,info {"time": 1654087140,"voltage_router": 12.8,"temperature_router": 37}
 08:40:00 script,info {"time": 1654087200,"voltage_router": 12.8,"temperature_router": 37}
 08:41:00 script,info {"time": 1654087260,"voltage_router": 12.8,"temperature_router": 37}
 08:42:00 script,info {"time": 1654087320,"voltage_router": 12.8,"temperature_router": 37}
 08:43:00 script,info {"time": 1654087380,"voltage_router": 12.8,"temperature_router": 37}
 08:43:58 system,info,account user admin logged in from 1.1.2.1 via winbox
 08:44:00 script,info {"time": 1654087440,"voltage_router": 12.9,"temperature_router": 26}
 08:45:00 script,info {"time": 1654087500,"voltage_router": 12.8,"temperature_router": 26}
 08:46:00 script,info {"time": 1654087560,"voltage_router": 12.8,"temperature_router": 26}
 08:47:00 script,info {"time": 1654087620,"voltage_router": 12.9,"temperature_router": 25}
 08:48:00 script,info {"time": 1654087680,"voltage_router": 12.8,"temperature_router": 27}
 08:49:00 script,info {"time": 1654087740,"voltage_router": 12.8,"temperature_router": 25}
 08:50:00 script,info {"time": 1654087800,"voltage_router": 12.9,"temperature_router": 27}
 08:51:00 script,info {"time": 1654087860,"voltage_router": 12.8,"temperature_router": 26}
 08:52:00 script,info {"time": 1654087920,"voltage_router": 12.8,"temperature_router": 27}
 08:53:00 script,info {"time": 1654087980,"voltage_router": 12.9,"temperature_router": 26}
 08:54:00 script,info {"time": 1654088040,"voltage_router": 12.8,"temperature_router": 26}
 08:55:00 script,info {"time": 1654088100,"voltage_router": 12.8,"temperature_router": 26}
 08:56:00 script,info {"time": 1654088160,"voltage_router": 12.8,"temperature_router": 26}
 08:57:00 script,info {"time": 1654088220,"voltage_router": 12.8,"temperature_router": 26}
 08:58:00 script,info {"time": 1654088280,"voltage_router": 12.8,"temperature_router": 26}
 08:59:00 script,info {"time": 1654088340,"voltage_router": 12.8,"temperature_router": 26}
 09:00:00 script,info {"time": 1654088400,"voltage_router": 12.8,"temperature_router": 26}
 09:01:00 script,info {"time": 1654088460,"voltage_router": 12.8,"temperature_router": 26}
 09:02:00 script,info {"time": 1654088520,"voltage_router": 12.8,"temperature_router": 26}
 09:03:00 script,info {"time": 1654088580,"voltage_router": 12.9,"temperature_router": 26}
 09:04:00 script,info {"time": 1654088640,"voltage_router": 12.8,"temperature_router": 26}
 09:05:00 script,info {"time": 1654088700,"voltage_router": 12.8,"temperature_router": 27}
 09:06:00 script,info {"time": 1654088760,"voltage_router": 12.9,"temperature_router": 27}
 09:07:00 script,info {"time": 1654088820,"voltage_router": 12.8,"temperature_router": 26}
 09:08:00 script,info {"time": 1654088880,"voltage_router": 12.8,"temperature_router": 26}
 09:09:00 script,info {"time": 1654088940,"voltage_router": 12.9,"temperature_router": 27}
 09:10:00 script,info {"time": 1654089000,"voltage_router": 12.7,"temperature_router": 26}
 09:11:00 script,info {"time": 1654089060,"voltage_router": 12.8,"temperature_router": 27}
 09:12:00 script,info {"time": 1654089120,"voltage_router": 12.9,"temperature_router": 26}
 09:13:00 script,info {"time": 1654089180,"voltage_router": 12.8,"temperature_router": 26}
 09:14:00 script,info {"time": 1654089240,"voltage_router": 12.8,"temperature_router": 27}
 09:15:00 script,info {"time": 1654089300,"voltage_router": 12.9,"temperature_router": 27}
 09:16:00 script,info {"time": 1654089360,"voltage_router": 12.8,"temperature_router": 26}
 09:17:00 script,info {"time": 1654089420,"voltage_router": 12.8,"temperature_router": 27}
 09:18:00 script,info {"time": 1654089480,"voltage_router": 12.9,"temperature_router": 26}
 09:19:00 script,info {"time": 1654089540,"voltage_router": 12.8,"temperature_router": 26}
 09:20:00 script,info {"time": 1654089600,"voltage_router": 12.8,"temperature_router": 26}
 09:21:00 script,info {"time": 1654089660,"voltage_router": 12.9,"temperature_router": 27}
 09:22:00 script,info {"time": 1654089720,"voltage_router": 12.8,"temperature_router": 27}
 09:23:00 script,info {"time": 1654089780,"voltage_router": 12.8,"temperature_router": 27}
 09:24:00 script,info {"time": 1654089840,"voltage_router": 12.9,"temperature_router": 27}
 09:25:00 script,info {"time": 1654089900,"voltage_router": 12.8,"temperature_router": 27}
 09:26:00 script,info {"time": 1654089960,"voltage_router": 12.8,"temperature_router": 27}
 09:27:00 script,info {"time": 1654090020,"voltage_router": 12.8,"temperature_router": 27}
 09:28:00 script,info {"time": 1654090080,"voltage_router": 12.8,"temperature_router": 27}
 09:29:00 script,info {"time": 1654090140,"voltage_router": 12.8,"temperature_router": 27}
 09:30:00 script,info {"time": 1654090200,"voltage_router": 12.8,"temperature_router": 26}
 09:31:00 script,info {"time": 1654090260,"voltage_router": 12.9,"temperature_router": 27}
 09:32:00 script,info {"time": 1654090320,"voltage_router": 12.8,"temperature_router": 27}
 09:33:00 script,info {"time": 1654090380,"voltage_router": 12.8,"temperature_router": 27}
 09:34:00 script,info {"time": 1654090440,"voltage_router": 12.9,"temperature_router": 27}
 09:35:00 script,info {"time": 1654090500,"voltage_router": 12.8,"temperature_router": 27}
 09:36:00 script,info {"time": 1654090560,"voltage_router": 12.8,"temperature_router": 26}
 09:37:00 script,info {"time": 1654090620,"voltage_router": 12.9,"temperature_router": 26}
 09:38:00 script,info {"time": 1654090680,"voltage_router": 12.8,"temperature_router": 27}
 09:39:00 script,info {"time": 1654090740,"voltage_router": 12.8,"temperature_router": 27}
 09:40:00 script,info {"time": 1654090800,"voltage_router": 12.9,"temperature_router": 27}
 09:41:00 script,info {"time": 1654090860,"voltage_router": 12.8,"temperature_router": 27}
 09:42:00 script,info {"time": 1654090920,"voltage_router": 12.8,"temperature_router": 26}
 09:43:00 script,info {"time": 1654090980,"voltage_router": 12.9,"temperature_router": 26}
Winbox was connected at 8:43.
Before - nothing changes
After - changed immediately to actual value and then started to drift
Also attaching screenshot for Grafana (blue - Winbox disconnected, red - Winbox connected):
Solved in 7.4
Thanks.
