Hi
I bought 4 of these and I am now just find them to be stinking piles of poo, thats my current thought.
I bought 2 for testing.
Connected them to 2 10G switches with the 2 x sfp+ ports, setup LACP and configured vlans off there, then I created vrrp’s to sit in each vlan.
Did some testing, mainly around performance, found it to be okay, bought another 2 to put in my DC.
When I come to do some work on them, like turning of neighbour discover, the router crashes and reboots, try changing the vrrp config crashes reboots. If i try and do this on 1 item it crashes if I do it to all the items crashes
Okay there might be an issue, but it seems to me like the VRRP isn’t working properly either, you would think when 1 node dies alls is okay, I have another device setup the same running vrrp to take over the dgw… no crash and burn, I have a 2-3 min outage … until the original node reboots.
This is just to fragile for any sort of production environment.
EDIT
I have sent a support-out to support… waiting … waiting … yawn
