FTP configuration problems with CRS326
Hello, I am new to this forum, my question is, is it possible to save “export” from a CRS on an ftp server? When I do it on a CCR the script works without problems but when I do it on a CRS it doesn’t work, it shows me a “failure: connection timeout” error.
This is the script I am using for version 6.49.6.
:global data ( [/system identity get name] . "-" . [:pick [/system clock get date] 4 6] . [:pick [/system clock get date] 0 3] . [:pick [/ system clock get date] 7 11] ."-". [:pick [/system clock get time] 0 10] );
delay delay-time=2;
export file=$data
set data($data. ".rsc");
delay delay-time=2;
tool fetch address=x.x.x.x src-path=$exp dst-path=$exp port=21 user=test password=test mode=ftp upload=yes
delay delay-time=5;
file remove $exp
delay delay-time=2;
And this is for version 7.x.
delay delay-time=2;
export file=$data
delay delay-time=2;
tool/fetch address=x.x.x.x src-path=$exp dst-path=$exp port=21 user=test password=test mode=ftp upload=yes
delay delay-time=5;
file remove $exp
delay delay-time=2;
I would be grateful for the information if anyone touches on this topic.
You are posting this in the SwitchOS section of the forum. If you are running the CRS326 on SwitchOS, there is no ftp functionality.
I’ve moved the topic. It beggars belief that the OP could have tried this and gotten that result on SwOS. The true issue must be something else.
