FTP firewall rule not working
i am using RB532 as a broadband router and i am kinda doing my firewall ruls in reverse order by dropping everything and allowing just the services i want. all my rules work great except my allow FTP rule. seems like the firewall is allowing port 21 but not 20.
Any suggestions
Thank you
/ ip firewall filter
add chain=input protocol=tcp dst-port=8291 action=accept comment=""
disabled=no
add chain=input protocol=tcp dst-port=3389-3390 action=accept comment=""
disabled=no
add chain=input protocol=tcp action=drop comment="" disabled=no
add chain=forward src-address-list="no internet" action=drop comment="Drop
internet access (see list)" disabled=no
add chain=forward connection-state=established action=accept comment="Accept
Established Connections" disabled=no
add chain=forward connection-state=invalid action=drop comment="Drop invaled
connections" disabled=no
add chain=forward protocol=tcp dst-port=20-21 action=accept comment="Allow
FTP" disabled=no
add chain=forward protocol=tcp dst-port=80 action=accept comment="Allow Http"
disabled=no
add chain=forward protocol=tcp dst-port=443 action=accept comment="Allow
HTTPS" disabled=no
add chain=forward protocol=tcp dst-port=110 action=accept comment="Allow
POP3" disabled=no
add chain=forward protocol=udp dst-port=123 action=accept comment="Allow NTP"
disabled=no
add chain=forward protocol=tcp dst-port=25 action=accept comment="Allow SMTP"
disabled=no
add chain=forward protocol=udp dst-port=53 action=accept comment="Allow DNS"
disabled=no
add chain=forward protocol=tcp dst-port=23 action=accept comment="Allow
Telnet" disabled=no
add chain=forward protocol=tcp dst-port=3389-3390 action=accept
comment="Allow RDP" disabled=no
add chain=forward protocol=icmp action=accept comment="Allow Ping out"
disabled=no
add chain=forward action=drop comment="Drop Everything else" disabled=no
[admin@edgerouter] ip firewall filter>
someone please chime in. This little problem is annoying
Did you try writing one rule for port 20 and another rule for port 21?
yes, i did try seperate rules to no avail. Thank you for the reply
are both ports 20 and 21 TCP ports ?
Thank you
Turn on the FTP helper in Firewall - Service Ports.
Add a rule to allow Related packets in the Forward chain.
Remember that FTP has two modes: normal & passive which manage their data channel in completely different ways.
Once you have this working I suggest you re-visit your Forward chain and specify an input interface for each rule to distinguish between inbound and outbound traffic. Also, specify ‘New connection’ for each rule.
Regards
Andrew
allow related connections did it!!
Thank you
