Hello.
I want set my FTP to global(visible to other Pc) but i dont know how. can somone can navigate by terminal or graphic how i can do that?
FTP works on my network when i type 192.168.1.101 (in Total commander)
this is my settings:
When i type what is my ip its say:
88.156.90.61
and i belive i need to add somthink in NAT?
i try is this:
add action=dst-nat chain=dstnat comment=“Na FTP server” disabled=no \
dst-address=88.156.90.61 dst-port=21 protocol=tcp to-addresses=\
and from this site:
http://gregsowell.com/?p=669
and its didnt work.
Hm..
Have you got access to the gw (192.168.1.1)?
If the answer is yes, then you need port forward on that device to your RB ..
If not, speak to someone that does and get him to do it for you, make sure you secure your ftp though.
Also, TFTP is not FTP. They are not the same and use different ports. You want FTP, under IP->Services. If you’re not using TFTP specifically, you should turn it off.
Yes I have access, already forward and its working
thank you so much for answer.
How set firewall right to protect my TFTP and network?
links or tutorials place.
Also i have question, this router have 62mb memory to use on TFTP. Can I set simple website and mail domain on it?
I am still learning.
thx
