FTP list directory - No files - Hotspot Login
Hi
I am using MikroTik RouterOS v2.9rc7
I have spent 2 hours trying to modify the html hotspot login files and I can’t even see them let alone modify them…
When I ftp to the router, the only file that appears is autosupout.rif
I have tried flashfxp, smartftp, winscp all with the same result.
Is there some simple thing I am missing?
I have read the manual and pulled the forums apart. Seem a few have had the same problem.
Shane
enter something in the “html-directory” field in hotspot settings. only then the files will appear. you should read the manual more carefully:
html-directory (text; default: “”) - name of the directory (accessible with FTP), which stores the HTML servlet pages (when changed, the default pages are automatically copied into specified directory if it does not exist already)
Wow… Thanks a lot…
I must have read that line 20 times and even entered “/files” thinking that was the root of the ftp directory.
Now I can play some more :slight_smile:
