FTP multiple logins
Hai there!
I have successfully enable my ftp server through mikrotik. I did the port forwarding. However i notice that only 1 user can passthrough the mikrotik to open the ftp. How can i enable the mikrotik to allow multiple users login?
thanks! :smiley:
I think this may help
/ip firewall service-port enable ftp
Realy? It enables internal ftp server on MikroTik IMHO. You dont need this to use ftp inside your LAN.
Gotmoh, you’re confusing this with /ip service, which
indeed controls services on the router itself.
–Tom
Check the FTP Server configuration.
I don’t think it’s the problem on Mikrotik.
If one user can login, it means the D-NAT / Routing / Firewall in Mikrotik correctly configured.
Me confusing? Or Mapik? :smiling_imp:
command
will enable internal ftp proxy in MT, which may help with this problem I hope
thanks for the numerous replies guys!! :smiley: i really appreciate it!
Mapik, i have enable the service-port as u said. my ftp is working already.
however…what i want is multiple users to use the ftp at the same time. currently only 1 user can use the ftp. mikrotik does not allow multiple users to use the ftp simultaneously.
is there a way to setup the mikrotik to allow more users using the ftp?
thanks!
