I’ve configured an rb450g with the network pro firewall rules adapted like this:
1 isp connection
not using proxies, natting some services to outside
new chain to filter outgoing packets
Everything seems to be working fine, except FTP connections. Sometimes (or some ip’s) i cannot get an ftp connection to work, it seems to be stucking at the list command.
I’ve already checked that the ftp service helper is active.
I’m using fillezilla as an ftp client, using a passive mode connection.
that is good that you caught them, now you can move this log rule through your sanity check chain and see where you are getting rid of them. If these are related, then they should be matched by accept established and accept related.
