FTP Problem on client pc's cant access FTP
PROBLEM ON CLIENT PC’S CANT ACCESS FTP
I have setup a ppoe server and everything is working well except the FTP sessions. It says connecting, then immediatly terminates the session, you barley get enough time to view the information in the status bar, then it says your connection to the host was terminated.
No other errors, have tried changing settings in IE and Firefox I have also tried changing values in the registry, and still no luck.
Is there anything else that I need to setup in Winbox for FTP to work.
I have only one route and that is for the pc’s to access the ether1 from all the wireless cards.
As I said above everything else is work 100%. But need help with the setup for FTP if there is any. I am new to this sort of thing, so I am dumb struck.
Have a little experience in Networking for home and small office but nothing like the router boards of mikrotik.
Any help with this will be greatly appreciated[/b]
have you set passive connections settings for FTP client on your client PC’s?
