I got an issue here, how to enable the FTP for the miktrotik?
It keep redirect me to the miktrotik `s FTP instead of my FTP server .
FTP Server IP: 192.168.1.2
WAN: public IP, when I click on (wan public IP) it will redirect to Mikrotik`s FTP not to my FTP server.
when it promp username and password: it only can access via routers* users* not using my AD server users.
Router does not redirect anything anywhere by default. If router has public IP and you connect to it, you connect to router’s FTP server. So you probably want to forward a port to your real server. For example, this would be the simplest case, which would work for unencrypted connections from WAN:
