ftp problem
oh forgot im using a module called pcc on my rb750 cuz im using 2 dsl routers for outgoing traffic.
i have setted up a pcc based setup all my rules are working right but the mikrotik does not redirect a public ip adress back to the user using ex: ftp connection on the same subnet like:
wan1:41.134.110.11 and wan2:196.212.100.148 wich is on my rb750 eth1
lan1:192.168.88.0/24
now on my local subnet i have a ftpserver with the adress 192.168.88.2 and im on my local subnet i try to access my ftpserver from outside my network like on my 3gphone with my wan ip 41.134.110.11 it works but on my local ip 192.168.88.0/24 it keeps on timeing out why does it do that?
Can you explain in more detail what is and is not working? I am confused.
Edit: Are you trying to access the public IP of the FTP server from the subnet it really is on, and that times out? If so: http://wiki.mikrotik.com/wiki/Hairpin_NAT
ok like the hair pin nat rule will work but is there a way so if the incert a ip like 41.134.110.11 it wil revert back to 192.168.88.2 ?
ok cool thank you it seems to be working for now! lol :wink:
now another thing is, is there a way to ping a certain ip adress on my public domain and if it cannot be reached it emails me and tells me router 1 down or do i need to write a script for that?
http://wiki.mikrotik.com/wiki/Manual:Tools/Netwatch
Though using a proper network monitoring application would scale better, Netwatch will let you monitor hosts and run scripts on state change.
