FTP server behind multiwan with load balance
Hi everyone!
I have 3 WAN load balanced with something adapted from
http://forum.mikrotik.com/t/howto-dual-wan-pcc-with-dynamic-ip/101969/1
The problem is that I have one FTP Server behind the router and I can’t fully connect to it.
I’ve added (on top)
add action=dst-nat chain=dstnat dst-address=<WAN1IP> dst-port=21 protocal=tcp to-address=<FTPSERVERIP> to-ports=21
and I try to access with one IP (WAN1 IP, the one used by IP/Cloud to get the URL).
I have to connect several times in order to actually connect because most of the time I get a timeout or a refused. Also when I’m connected and trying to list contents, sometimes I also get denied.
I’ve tried adding “Dst. address” and “In. Interface” to the NAT, but I get the same results.
What’s wrong with the setup?
Read wikipedia about FTP. It has more than one connection by design so related connection (data connection) probably just goes through another WAN.
You can try to switch passive/active mode in FTP settings.
More robust design is to mark ftp server traffic in mangle and bind it to single WAN.
Thanks for your answer!
I have lots of clients using the server and some aren’t tech savvy so I don’t want to force them to hunt for the PASV setting. I’ll try to solve it configuring the router first. I had a TPLink TL-R480t+ that worked so I assume I can make this Mikrotik work as well…
Ok, we are heading somewhere with this. I can mark port 21 but, how do mark the data coming from an unknown data port?
Make all traffic from this pc go through only one wan by src-address so no load balancing for this pc
