FTP SERVER
hi friends
i install Router os in a dual core pc with 160GB HDD. is it possible to use free space as a ftp.
os i can downlaod file via http ?
sorry for my bad english
Yeah you can use the free space for FTP.
tnx
how can i do that ? i want to use it as a web server ? is it possible? if http not possible , how can i use it as a ftp server ?
YES! Just connect with FTP to your router, that’s all
like ftp.192.168.202.1 ?
user : admin
pass : **** ?
yes …
Status: Resolving address of ftp.192.198.202.1
Status: Connection attempt failed with “EAI_NONAME - Neither nodename nor servname provided, or not known”.
Error: Could not connect to server
pleas can you post more details ? how can i connect with ftp ?
thanks
:smiley:
you typed ftp.192.198.202.1
don’t type ftp in front of it, ONLY the IP address
ok thank you very much problem solved
can i access ftp files via http ?
how can i creat dir on ftp ?
thanks
can’t / can’t
to create directories on ftp server use the usual commands that ftp server provides to you.
long in though ftp and typ command help to see the commands.
edit:
forgot to add - do not count on it as a usual ftp server, because it is not. On the other hand - for personal use for 1 user it will be ok.
