Has anyone encounter like this also?
I have RB951G-2Hnd works almost 1 yr already upon upgrading of firmware my speed become very slow… but when I put my LAPTOP direct to MODEM I got the 200MB but using RB951-2Hnd becomes 50% speed or lower than that… any problem with the firmware?
Dex
This implies that the router is certainly capable; https://mikrotik.com/product/RB951G-2HnD#fndtn-testresults
Most likely an issue with your configuration. Can you post an export for all to see?
At that speed you should make sure fasttrack is working, I have 500mbps with fasttrack no problems.
Main problem is 10/100 Ethernet ports, so its impossible to get more that 100mbps using one port. Upgrade to new device like HEX with 1gbps port.
It is RB951G - it has gigabit ports. I believe you got it confused with “non-G” version
