I apologize if this has been asked a lot, but I have a network setup using three RB911G-2HPnD radios and I am using WinBox v2.2.18 to configure them. Is there a quick an easy way to export the full radio configuration? Now that the network is fully up and running I would like to have a concise record of the configuration. Plus, if I have to setup another one of these it would be beneficial to just import the settings into the new network and then tweak as necessary.
I was able to find some documentation but I was hoping on getting some clarification before I do something that may mess something up.
Mikrotik Wiki, configuration management
http://wiki.mikrotik.com/wiki/Manual:Configuration_Management#Exporting_Configuration
So, I should just be able to open up a terminal in WinBox and type the command “export” and name the file. This would then save a configuration file on the radio, right? How do I get it off of it?
Also, would this configuration file contain all of the information and settings of the original? Such as SSID, frequencies, etc?
Regards,
