Full link
Hi.
Can you say something about what values The Dude uses to mark a link as full? Is it possible to set a fixed rate (say SHDSL 2 mb/s) as the top link speed, and make it say it’s full at a given rate (say 1.9 mb/s) ?
tjc
Full link speed is taken from snmp variable ifSpeed, but going make
possibility to override it next version with user settable value (in Link
properties).
Actual link color is somewhere between link color and link full color by
taking into account max of current link rates (either rx or tx) and total
link speed.
By default links are drawn in any color that is between black and red.
Did this ever presumably happen? Because I can’t get ANY part of this feature to work.
The values I set in the Speed field in the link definition don’t seen to affect ANYTHING.
When I display [Interface.Speed] in the link labels, I get 10Mbps for “wireless link” and “some link,” 100Mbps for all “fast ethernet” links, and 0Mbps for links between UBNT devices (I understand from elsewhere that there’s some sort of UBNT firmware bug involved).
But what’s worse is that the feature doesn’t even to work with THOSE values. Links are showing up as pink on my map when they are running well under 10% of both the [Interface.Speed] and the Speed field values.
