Full table in CCR1016-12S-1S+
Hi All,
I have 2 Mikrotiks (CCR1016-12S-1S+) currently in a multihomed setup. We have a /23 that we’re advertising but we are only accepting the default routes from both providers. I know this is not the best way to multihome but I am not sure if my 2 routers can handle the full table. Anyone using the above routers in a similar situation and how is the performance?
Thanks,
Jay
It’s possible, but convergence time can be horrible.. between 5 and 15 minutes.
Convergence time in BGP with CCRs is very dependent upon your upstream provider as well as the CPU load. I’ve seen it happen as quickly as a couple of minutes and as long as 10+ mins.
Test it yourself (in a non-production CCR) by using this VM and you’ll know what your best case scenario will be.
http://www.stubarea51.net/2016/01/21/put-500000-bgp-routes-in-your-lab-network-download-this-vm-and-become-your-own-upstream-bgp-isp-for-testing/
Also take a look at the CCR1072 BGP performance testing we did as a rough guide.
http://www.stubarea51.net/2015/07/25/mikrotik-ccr1072-1g-8s-review-part-2-bgp-performance/
Thanks Cegner and IPANetEngineer. I wanted to get some feedback to gauge whether we can do with these 2 routers or upgrade. Your comments have added to my push for an upgrade.
Many thanks
