hi,
I wonder if someone can help me to get dude to read Device.CustomField2 which in this case is the frequency set on a radio and then check against the snmp value from the actual device. OID 1.3.6.1.4.1.41112.1.4.1.1.4.1
This is mainly to see when or if a radio has jumped channel due to DFS.
I have no idea how to do this im sure its quite simple function
Hope someone can help!
Stewart
Using CustomField2 as a processed value doesn’t seem possible…
Try this type of thing on the appearance of a device label and you get Device.CustomField2 instead of the value in the field.
[if(Device.CustomField2=2412,"stuff","no stuff"]
[oid("1.3.6.1.4.1.9.9.272.1.1.2.15.1.6.1.1",10,5)]
[if(oid("1.3.6.1.4.1.9.9.272.1.1.2.15.1.6.1.1",10,5)=2412,"stuff","no stuff")]
[if(oid("1.3.6.1.4.1.9.9.272.1.1.2.15.1.6.1.1",10,5)=Device.CustomField2,"stuff","no stuff")]
anyone?
Lebowski
