Draft network diagrams. I need to find a better diagramming tool since I no longer have Visio. I’m usually more accustomed to designing in the company’s CMDB and letting it generate the drawings, so I apologize that my home network diagrams are so primitive.
(EDIT: The forum doesn’t like the Google Drive links as images, so I’m converting them to raw.)
Not that it changes anything, but if you decide that the emergency management port is ether1, you should have ether1 as mgmt also on the router.
The “usual” convention in Mikrotik is the opposite (the reserved emergency management port is the last one and ether1 or SFP1 is the one “towards outside”, i.e. uplink or internet/ISP) but yours, if consistent, is good as well.
Yep, on most if not all Mikrotik routers (the SoHo ones, including Ax3) the default configuration is with ether1 as WAN and all other ports into a bridge as LAN.
Some devices even have (had) ether1 marked as “internet” on the case.
Even if on a switch it makes no real difference, It makes sense to use the same order, though of course it is just a mnemonic.
And once one has become familiar with the settings and the configuration has been tested, and backup/exports have been made, the “emergency” access can be removed and the interface be put into “normal” service, the “extra” port is a luxury that devices with only 4 or 5 ports cannot often afford.
I found this in the official documentation (VLAN Switch Chip Features Setup Examples). It’s needed so the VLAN traffic becomes available to the CPU for L3 functions that aren’t offloaded to the switch chip. It’s also mentioned under Bridge VLAN Filtering. Both of these are in amber-highlighted text blocks.
I’ve learned something about the Syn Timeout failure to connect from WinBox to the Mikrotik devices by MAC address. On my laptop (Arch Linux), I’ve defined two “network connections” on the same Ethernet port, in Network Manager. They both have automatic connection disabled. One is automatic config via DHCP to use on my regular network, while the other has a static IP address and is used for direct connection to the devices.
If the Ethernet cable is moved from port to port or device to device, or if the DUT is reset (even a soft reset of the switch chip), the Linux network stack is notified that the port was “down” and will reconfigure its network connection when the Layer 1 connectivity returns. In my case, Network Manager does not restore the last manual connection I had used, but instead leaves the port unconfigured.
Using WinBox at the MAC level, it “sees” the MAC addresses of the devices but can’t connect to them, throwing that Syn Timeout error. If I re-establish the manual connection in Network Manager, MAC connectivity to the Mikrotik device works again.
It was not intuitive to me that a purely Layer 2 connection would require Layer 3 to be “up” on the laptop, but it has to do with Network Manager’s internal behavior with an interface that is (temporarily) not “connected” to a configuration.
Hopefully, this saves some aggravation for someone else.
I’ve been trying out draw.io but made the drawings in Libre Office Draw for now.
Having stepped away from the Mikrotik work for a while because of work projects, I returned to it yesterday and today. I now have working LACP bond ports among all three switches. New! Improved! Now with pings that don’t time out! I also have part of the VLAN stuff working, and should be good to go on that once I reconcile the differences needed between the CRS switches and the hAP router (which lacks the switch offload).
My new config adopts nearly all of the advice so kindly given here, including:
The router shall route, the switches shall switch, and there shall be no router-switch mishmash.
The last physical port on each device is the emergency management access now and is a non-bridged port with an IP address of its own.
And of course I’m configuring the bridge and interfaces very similarly to the recommendations here.
