IM getting the same problem, i follow the exact stuff to the T in the wiki and i get an error message on “Unknown Type” when i try to add the data source
OK its prolly a bug in the Dude , cuz if you add the chart then remove it and and the use the undo button to bring it back , it then lets you put the data source in without giving that error of unkown type. Seems to be working doing that , kinda annoying haveing to make and delete then bring back the chart b4 u add the data source to it , but oh well at least it works
huh, that’s funny. i’ve got the same issue but i work around it by adding a new chart, and then clicking OK without nameing it. then i right click it and hit settings. from that point i can do whatever i want, including renaming the chart, and adding data points.
But I removed and re-added and it didn’t work. AHA! She cried, use the “OK” and not the “Apply” and it worked.
Finding that with a few Dude things, when adding notes for example apply puts in the default 1970 date, OK puts in the correct date. Maybe it’s related to that same issue. Just my .02c.
