funny configuration with pppoe and local lan
Hi i have a need to make this funny conf so maby You will try to help :slight_smile:
I have fast ethernet network with gatway 192.168.0.1 and the pppoe server(10.0.0.1) on the same core router(MT)interface. dhcp is for free users (192.168.0.0/24) and pppoe is for pay ones (10.0.0.0/24) the think is some of them want to have pay internet for two computers (i have no problem with this) but with standard router (non-MT :smiley:) thay lose the free and fast (100M) connectivity to other host in subnetwork (192.168.0.0/24) bacouse the router connect only via pppoe…
any ideas ?
i try some but nothing seamse to work… maby the way is to put router there and add pppoe-client, dhcp-client without default route (it should be only one from pppoe ), dhcp-server in another subnetwork like 192.168.88.0/24(for those clients) masquarade it to pppoe interface ?
any one tried such magic any time in the past?
in general, that non-MT router should use both IP and PPPoE on the WAN interface
yes :slight_smile: but i will use rb750 for them…
but i was thinking about using bridge that allow them to use lan ip’s (not nated again) and use pppoe for internet(here should be nat I think) and they just use gatway of the rb750.
Is that possible?
using another subnet and nat it to the lan and pppoe is easy :slight_smile: i want harder option :slight_smile:
so simply use both dhcp-client and pppor-client on RB750 =) and in dhcp-client, uncheck ‘add default route’. then masquerade all user’s computers both on ether and pppoe-out
