FWF FIRMWARE FOR ROUTERBOARD
WHERE CAN I GET ROUTERBOARD FIRMWARE 2.23 fwf FILES
RouterBOARD firmware upgreade is included with RouterOS, so you can simply upgrade RouterOS to v5.16 and run “system routerboard upgrade” command to upgrade firmware.
If you don’t have RouterOS, you can get the files from RouterBOARD.com site, open any product, and check file box on the left.
When I applied 5.16 recently, it took my firmware to 2.39. This isn’t the version the original poster is after?
HI NORMIS ,
I REQUIRE 2.23 FWF, I DONT WANT TO UPGRADE ROS
CAN YOU GUIDE TO DOWNLOAD 2.23 FWF ONLY
why do you need old firmware if you can use new one from routerboard.com?
THANKS DEAR,
I WANT TO MAKE ALL BOARD ON SAME FIRMWARE & SAME ROS, HENC I NEED OLD FWF,
THANKS, IF CAN SEND ME FWF FILES ON SAMIRATDCG@YAHOO.COM
It’s a very bad idea to make all devices at same OLD firmware. Better make them all same new firmware and software
aggred , but each ROS having different firmware
I AM USING 4.3 ROS & WITH THAT I WILL 2.39 AS YOU MENTIONED,
IS IT OK TO LOAD ROS 4.3 & FWF 2.39 ?
Use v5.16 instead.
hi ,
from where i can get firmware for RB333 ?
RouterOS v5.16 for RB333:
http://download2.mikrotik.com/routeros-powerpc-5.16.npk
