Game Servers and GiTea problem
Hello everyone, I bought Mikrotik(hap ax2) for the first time after many years on TP Link, so I ask for your help.
We have 2 computers:
  1. 192.168.88.251 - a computer with 3 DayZ game servers
    Required ports:
    2302-2308, 27016, 2312 - first (TCP + UDP)
    2402-2408, 27017, 2412 - second (TCP + UDP)
    2502-2508, 27018, 2512 - third (TCP + UDP)
  • 8766 bonus port
  1. 192.168.88.252 - home GiTea server
    Required port 3000 TCP
Before I changed the router, on TP-Link I simply reserved the MAC address of the first computer and set it to 192.168.0.200 (so that it was outside DHCP) and the ports were also open. This was enough to:
  • the game servers were visible on the Internet
  • they could be connected to
  • they were visible online (Steam Querry) in my case it was 27016, 27017 and 27018 respectively for each server.
On Mikrotik there are two problems:
  • Gitea does not work
  • The game servers do not show online, but players can connect and play too.
What settings did I do:
  1. First of all IP > DHCP SERVER > LEASES
    I did "Make Static" both 192.168.88.251 and 252
  2. IP > Firewall > Nat
    I created rules:
    UDP separately and TCP separately for each range
    a) 2302-2308
    b) 27016
    c) 2312
    d) 2402-2408
    e) 27017
    e) 2412
    f) 2502-2508
    g) 27018
    h) 2512
    i) 8766
    with the following settings:
  • chain dst - nat
  • protocol - udp and tcp separate rules
  • port specified in "dst.port"
  • in interface "ether1"
  • action "dst.nat" + "to addresses" set 192.168.88.251
Also entered these commands:
/ip firewall filter disable [find action=fasttrack-connection]
/ip firewall filter add chain=forward action=accept connection-nat-state=dstnat place-before=11
/ip firewall connection remove [find]
Hi, would you kindly do an export of your config and post it here?
/export (file=anynameyouwish) (minus sensitive info like serial numbers, passwords, etc. If you export as a file, the .rsc can be opened using any text editor).
Some preliminary questions:
  1. Does the online appearance of the servers rely on DNS and does the router act as a DNS server?
  2. What exactly doesn't work on the Gitea server?
