GBIC Finisar FTRJ-1319-7D-2.5
Does anyone know if the GBIC Finisar FTRJ-1319-7D-2.5 works with RouterOS???
BR
Another forum post
For Info only . Ticket#2013100166000457 with this same question to support :
by standard it should work with RouterOS, however if you are going to use it in our
hardware I recommend to use 1.25G transceivers, for which our products are designed
for.
Regards,
Krisjanis
BR
I am using the Finisar FTLF8519P2BNL and confirm these are working on RB2011U and RB260GS.
